There are two lots of bearings in an S7 clutch, the pulley containing the bronze clutch plate has two ball races and the main shaft has two plain bronze bearings. If the clutch rumbles while it is disengaged then the ball races need attention but if it rumbles while the clutch is engaged then maybe the plain bushes are loose but it would be odd for them to cause a rumble I would have thought. Are the belts in good condition? And are all the pulley grub screws tight and woodruff keys in good condition? There is a thrust race in the clutch end main shaft bearing housing, are the circlips that locate the main shaft in their grooves?
The clutch can be removed as an assembly by removing the grub screw from the multi v pulley, check there are not two in the hole, this should let the multi pulley slide along the main shaft, remove the circlip adjacent to the thrust bearing, it will slide along the shaft, you should be able to expose the woodruff key for the multi v pulley and remove it with pliers. The whole clutch and main shaft can now be withdrawn and a small spring and ball bearing will escape from the push rod end of the shaft, it may be found in the operating lever housing or fall out while the shaft is being withdrawn, look out for it. Shaft and bush wear can be assessed at this point and the condition of the thrust bearing.
To dismantle the clutch further you will need to compress the spring and be able to unscrew the driving key from the centre of the clutch which will just leave the pulley and bearings on the shaft which will need to be pressed out by whatever means you have.
It may not be necessary to totally dismantle the clutch depending on what you find, the pulley bearings can be given an inspection by disengaging the clutch and removing the belt, if it spins smoothly it may be ok but sometimes things only really show up when under belt tension and loaded.
Reassembly is straightforward as long as you put all the bits back on the shaft in the right order, don't forget the circlip, the ball and Spring will probably require the help,of some thick grease and bad language but it can be done. If the clutch lever is removed I would replace it before the main shaft as I would say it is impossible to fit the ball and Spring and then the lever. Before taking anything apart I would try and pin down the rumble, dropping off the belts might narrow it down. Run the motor on its own then add the first belt and try the clutch in and out then the second belt and clutch in and out, this might build a picture of where the trouble lays. The manual has a sectional view of the clutch and is worth studying in conjunction with your machine to see how it works.
Edited By Mike Poole on 13/02/2017 17:02:00
