Myford Lathe Tool Inserts
Home Forums Workshop Tools and Tooling Myford Lathe Tool Inserts
  • This topic has 28 replies, 17 voices, and was last updated 2 May 2018 at 18:56 by duncan webster 1.
  • #352282
    chris stephens
      @chrisstephens63393
      Hi Guys, are we forgetting that Myford, the original one, once supplied tangential toolholders?
      Hillclimber
        @hillclimber
        This was the 'easy-set' toolholder, and designed to slap straight on to the topslide. Uses circular HSS. There's a photo of a set at the bottom of the page for this advert on 'lathes'…
        http://www.lathes.co.uk/advertphoto/160415myfordaccessories/
        Funnily, I have just acquired one of these to try. I have been using AR Warner HSS inserts to improve finish on an indexable tool, and thought I would give one of these older systems a bash.
        Point is that it should provide for the simplest setting and regrinding of HSS tools for the less confident/ experienced, by which I mean me.
        Cheers, Colin
        #352354
        chris stephens
          @chrisstephens63393
          Hi Collin, that's the kit but from that picture you can't see the squared ends of the other 'inserts'. I bought an unused set at a SMEE rummage sale, was not overly impressed compared to one of my homemade but have not experimented with varying the top rake yet, maybe one day.
          #352551
          duncan webster 1
            @duncanwebster1
            This thread put me in mind of a tangential flycutter. Found this link
            but to me it looks as tho the tool is angled wrong and has negative clearance against the cut face. it should be angled the opposite way. Or am I missing something?
