So I spent a few hours today tryung to get the L510s VFD to run the lathe. i did a factory reset of the VFD, I confirmed the remote control box is wired correctly to the VFD. I set the motor parameters correctly from the plate into the VFD as follows:
I got the motor settings from the plate, as follows:
W 550
RPM 1425
V 380/440 – 220/250
A. ^1.5 *^ 2.6
H 250
I therefore made the settings on the L510s as follows
02-00 MOTOR No Load current 1.5
02-01 Motor rated current 2.6
02-03 Motor rated speed 1425
02-04 motor rated voltage 220 ?
02-05 motor rated power 0.5 as in kw. I couldn't set it to 0.55. ?
02-06 motor rated freq 250
I then attempted to change the 00-02 setting to run by default from the key pad and not the remote control. Despite the reset it was still set to “1” (remote) and wouldnt change, giving me an Err 1 message when I tried. I also attempted to change the default direction from fwd to rev, but again it wouldn't let me.
Despite all that, it still only runs in reverse and with limited control. If I change the fwd/rev setting on the lathe it makes no difference.
Tomorrow I will double check the wiring inside the remoTe control, and perhaps consider switching the T wires to reverse the running…
any thoughts welcome! Happy to post pics of the wiring and my notes on that if that helps. Very very grateful for all the kind offers and thoughts.
Roger
