Thanks for the video link – yes, that will come in handy – thanks.
Light Straw. Yes, I work for BT and there's still plenty of ironwork painted that colour in the exchanges. Maybe that is what my "custard yellow" was intended to replicate ?
However, colour wise, I've settled on Grey & red.
Re. the bearings, yes, will get SKF ones, Hopefully should last me out. Ta.
As for the saddle to bed clearance, Ive gone over it with my 2 thou feeler gauge and I can't get it in anywhere so pretty chuffed about that. There's the odd place I can just about squeeze the 1.5 thou feeler in (the thinnest I have)
I have given up on trying to extract the brass oil dripper tube from the headstock – it is indeed very tight and if I force it more something is going to break. I will attempt to make a replacement plastic "thimble" from nylon bar and slot it at the back to go around the tube, like you say. I am tempted to make it a fraction longer and put an O ring under the bezel. I will have to wait till the lathe is up & running first, so I'll just put some tape over the hole in the meantime.
The thimble has (as far as I can measure) a 22mm X 0.7mm thread. Does that sound right for a Myford of that era – I would have expected imperial measurements ? Or am I measuring badly ?
If so, should I be able to cut such a fine thread on my S7 when I get it running ? I'm a complete newbie to threadcutting though I have watched a fair few youtube videos on the subject.
Dave.
