Marking out
Marking out
Home › Forums › Beginners questions › Marking out
  • #4698
    Crocadillopig
      @crocadillopig
      #41981
      Crocadillopig
        @crocadillopig
        Hi All
        Back in the sixties we used Marking Blue and Copper Sulphate, the latter was far superior for fine work, etching the workpiece with a light brown patina and didn’t wear away with the use of coolants. I believe it was made up of copper sulphate crystals and sulphuric acid ! My question is what was its composition and in what ratios ? Also is it available commercially in small quantities, if not where can I obtain the ingredients.
        Hope someone can help.  Russ
        Edited By Russell Wigley on 22/06/2009 11:57:37
        #41984
        David Clark 13
          @davidclark13
          Hi There
          I believe it was copper sulphate solution.
          No acid involved.
          regards David
          #41990
          Circlip
            @circlip
            Dave, Copper Sulphate (CuSo4) is copper disolved in sulphuric acid. Get some battery acid Russ and chuck some bits of copper into it (Scrap preferably) and leave until no more will disolve in it. Solution will be a green colour (Like Kryptonite) ALTERNATIVELY you could use the remaints of a pickle bath if you said “Damn the Elfins” and used battery acid let down to a reasonable level and dunked yer copper boilers in it after silver soldering them ORRRRR, the REALLY whimpy way, by getting some Copper Sulphate crystals from the Chemist (Yer gonna have to tell him what yer want them for) and mixing with diluted H2O (Water). Oh aye, trade name was “Killed Spirits” and we also used it as flux for NON electrical soldering, —–  Tinplate days.
               Regards  Ian.
            Edited By Circlip on 22/06/2009 16:39:43
            #41995
            David Clark 13
              @davidclark13
              Hi There
              That is why I got it wrong.
              I just bought the crystals.
              regards David
              #41997
              Circlip
                @circlip
                Eeeeeeeeeeeee, that nobut a bairn David lad but we’ll turn thee into an Ingineer yet
                   Regards  Ian.
                #41998
                HasBean
                  @hasbean
                  Ahh yes, killed spirits.
                  My grandfather was a plumber and used to buy hydrochloric acid in carbouys. My job on a Saturday as a 7 year old was to sit in front of a bucket of HCL with a pair of tinsnips and a sheet of zinc making the stuff!
                  Every now and then he’d pass by with a lighter and ignite the hydrogen!
                  I think Mr Elfin Safety might frown upon this these days.
                  #42006
                  Circlip
                    @circlip
                    Oooops Eretta, could have been “Spirits of Salts” —- All Zimmers.
                       Regards  Ian.
                    #42008
                    Frank Shaw
                      @frankshaw82412
                      hi guys, check out “Copper Sulphate” on Ebay.
                      there are several suppliers of quick dissolve crystal there.
                      this could be what you are looking for.
                      Rgds
                      Frank
                      #42265
                      Chris
                        @chris16039
                        Just a beginner but if you spray sheet sheel with cheap primer, grey or better white it gives a great surface to draw on with a pencil. try an H2, very fine line and if you cock up you can rub it out. Bought my last tin of light grey from a pound shop for, guess what. Just a quick flash over with the spry can is enough.
                        Chuck it in some celulose thinners for five minutes and wipe it over with some fine wire wool and hey presto! You might not need to ’cause your going to paint it anyway.
                        Never tried it with brass but I’ll get back to you when I have.
                        As a newby I just know someone is going to tell me this is a really bad thing to do.
                        Chris.
                        #42273
                        Niloch
                          @niloch
                          Posted by Chris on 10/07/2009 22:50:31:
                          Just a beginner but if you spray sheet sheel with cheap primer…………..
                          Chris.
                           Not me Chris, but then I’m a novice too more interested in horology than the heavy stuff.
                          John Parslow, in the very first instalment of his serial on a 15 day Skeleton Timepiece (ME 4322 – 28/03/2008)says:
                          “Polished plate is supplied with a protective film on both sides.  I suggest stripping off this film and spraying both sides with two or three coats of red oxide primer paint available in an aerosol can from motor accessory shops.  This will protect the surface from accidental marks and scratches and provide an excellent surface for marking out with pencil or scriber”.
                          I’ve also used blue ‘Magic Marker’
                          #42337
                          WALLACE
                            @wallace
                            Cromwell tools do marking out blue in 500ml bottles which appeared to be most cost effective. I would recomend decanting some into a smaller bottle (plastic !) as it will make an awfull mess if knocked over .  .
                            WALLACE
                            #42353
                            Ian S C
                              @iansc
                              Hi wallace,an empty nail polish bottle just the thing,brush included!I use felt pen. Ian.s.c.
                              #42359
                              WALLACE
                                @wallace
                                Thanks for the tip. I’ll start saving mine up from now on !
                                W.
