Afternoon everyone,
I am trying to work out how I can direct index a lathe spindle to allow me to cut 18 internal splines with a single tooth cutter (it's only brass) using a 40 tooth spindle gear.
I can do the indexing on the mill and rotary table but it's really awkward getting the small cutter lined up and the mill has no spindle lock to prevent the cutter from rotating
My working-out so far is:
360 / 18 = 20° …rotate the lathe chuck every 20° and make a cut.
I need to figure out how many teeth I should count so that I get a multiple of 20° yes?
I initially thought it could be 9 teeth, 360 / 40 = 9 …but trying a test piece and drawing it out in CorelDraw confirms that is wrong.
So is this going to be like an indexing head where it uses one full rotation plus a number of teeth? or is it just not possible?
As always I appreciate any help.
Kind regards,
Ed.
