Laser centre finder
Laser centre finder
Home Forums General Questions Laser centre finder
  • #383985
    Stephen Follows
      @stephenfollows82099
      I have been looking at a laser centre finder that fits permanently to a pillar drill. I would like to fit one to my Warco mill but the drill one will not fit. Cannot find on that does. Has anyone fitted such a device to a mill?
      Stephen Follows
        #383997
          Stephen,
          May I suggest that you read this thread: **LINK**
          https://www.model-engineer.co.uk/forums/postings.asp?th=92281
          There was some very useful discussion.
          Personally; I don't think that a "pillar drill" style of device would be sufficiently accurate for use on the mill … but your requirements may differ.
          geoff adams
            @geoffadams14047
            Stephen
            i have a laser center finder it has a 6 mm shank and will fit any drill chuck i use on my mill drill and cnc mills got from ebay i think it was £50.00 well worth the money
            i got a tormach cnc mill about 3 months ago and it has probing on it been playing with it over the weekend can find center of a bore corner of a vice or probe two edges to set a datum at the touch of a button wish i had this back in the 80s when i was setting and programming cnc mills on more edge finders and clocks
            Geoff
            #384064
            Stephen Follows
              Thanks for replies. Looks like the collet mounted type is the answer for decent accuracy.
              #384186
              Jon
                @jon
                Its only as accurate as the lasers zeroed, plus theres way too much spread to pinpoint.
                Theyre that good i imported a quality one from California when first came out 2002, initial trial twice and never used since. You will get a far more accuracy with mark 1 eye ball.
                #384188
                Phil Whitley
                  @philwhitley94135
                  try this one, on the very excellent Dan Gelbarts you tube channel.
                  Phil
                  Edited By Phil Whitley on 06/12/2018 19:48:21
                  #384234
                    Posted by Phil Whitley on 06/12/2018 19:47:53:
                    That would be the commercial version of the one that started our discussion in 2014
                    … as per my post, above.
                    bricky
                      @bricky
                      I have one and use it on the mill for setting vice jaws true.When drilling to a centre pop I use a sticky pin as I am never quite sure that the beam is centre of the pop.I find the sticky pin near enough as any drill can wander slightly and I am not a toolroom fitter and never will achieve those tolerances and I dout many do.
                      Frank
