How do you fight workshop/shed condensation
Home Forums General Questions How do you fight workshop/shed condensation
Viewing 25 posts - 1 through 25 (of 39 total)
  • #135293
    ronan walsh
      @ronanwalsh98054
      The dreaded condesation has returned to my shed for the first time this winter. Went into the shed today and was shocked at the amount of water condensed on my old mill, i could have sponged it off there was so much. Time to insulate the building me thinks and find some way of heating it that doesn't cost a bomb.
      How do you fight this destructive pest ?
      ronan walsh
        @ronanwalsh98054
        #135300
        Thor 🇳🇴
          @thor
          Hi Ronan,
          this topic has been discussed before:
          ***LINK***
          Have you read it?
          Thor
          #135301
          michael cole
            @michaelcole91146
            If you only do one thing then that has to be insulate.
            #135306
            john fletcher 1
              @johnfletcher1
              Insulate as Thor says and then get a dehumidifier, they don't use a lot of electrical energy as they cycle on and off as necessary. Look out at sale rooms for cheap buys or buy new.I can recommend them, I've had one for the past 20 years pre owned. Alternatively get some bags of selica gel and dangle them around, they will change colour as they absorbe the moisture, but they will need drying out as and when necessary.Ted
              #135317
              Bob Youldon
                @bobyouldon45599
                Condensation can be managed but the elimination of the problem may involve some drastic action. You don’t say what method of construction your workshop is, the worst cases are the concrete garage shared with the car. The type of construction does determine the type of action required, to combat the condensation problem. Insulation is imperative and needs to be installed with a vapour barrier if it is to be effective. You need to determine where the condensate laden air enters the space and seal off any voids and gaps around ill fitting doors etc. a concrete floor can be a problem if no insulation was incorporated in the original build, there are specialist products able to deal with this type of problem although a vapour barrier and an industrial grade floor covering will much reduce any condensation from this source.
                Ventilation is important and modern heat recovery units are the way forward, particularly effective with today’s spiralling energy costs, see **LINK**
                The provision of some background heat is also necessary in lifting the dew point; this may be done with a simple electric tubular type heater, although I find a wall mounted fan heater far more effective as air circulation around machinery, benches etc is so important, see, Dimplex PFH30 3kw Commercial Fan Heater (DIMPFH30)
                There is little doubt good insulation to all surfaces, with correct ventilation will deal with the condensation problem once and for all.
                Bob Youldon
                #135319
                  My workshop is well insulated, but: For extra confidence, I have a 150 Watt "heating cable" that I just drape over the machines. The element is about 10ft long and was intended for horticultural use. It provides a warm micro-climate just where it's needed.
                  Thinks: You could probably strip the cable out of an old electric blanket
                  David Clark 13
                    @davidclark13
                    Large dehumidifier and empty it daily.
                    Tubular greenhouse heater behind the lathe cabinet if possible, available on Ebay.
                    Little trays of chemicals sold for putting on radiators.
                    I used a blanket over the lathe for two years with no rust but others may not recomend this as theoretically it attracts water.
                    #135325
                    Jerry Wray
                      @jerrywray14030
                      David,
                      What do you mean by a large dehumidifier? My garagve workshop is about 20'x10'
                      JerryNotts
                      #135326
                      Bazyle
                        @bazyle
                        A natural fibre blanket or sheet is a good idea David as the fibres actually absorb moisture whereas synthetic just has little droplets on its surface which can then contact the metal. A few bamboo sticks can help reduce contact with the machine.
                        Humans breath out and sweat up to 6 pints of water per day. That's to give you an idea of the problem you yourself create. So those little chemical packs haven't a hope except inside small toolboxes.
                        The first thing should be draught control to stop wet air coming in . Then some of the mositure can either condense on the inside of the roof or the window in preferance to the tools. A dehumidifier positively removes it. I don't have to empty mine every week once it had sucked the damp out of the structure.
                        Ventilation is essential once you are in there to remove the fumes and oil vapour but not moisture. The air should be dry enough from your dehumidifier to take a pint or two from you.
                        If possible heat the tool not the room, that way the tool is hotest and won't attract damp.
                        #135328
                        Ady1
                          @ady1
                          That's the cheapest simplest approach
                          I presume it stops moist air circulating around the object, but unlike with plastic etc, evaporation is possible
                          #135329
                          jason udall
                            @jasonudall57142
                            Condensation comes from water vapour in air . This happens when the ability of air to hold moisture drops below the amount in the air..
                            This is why they talk about RELATIVE humidity. .
                            So air comes into contact with cold mc..condensation happens..
                            OK insulate is the cry..
                            Well it helps in part ..1 seal up drafts..2 makes temp changes within workshop slower..3 allows a little heating to keep all in workshop above the dew point..
                            Frankly short of anti condensation heating ( cheaper than dehumidifiers..unless workshop is air tight) .. all insulation does is slow down the temp drop…
                            As to anti condensation heating ..well the dehumidifier works as a heat source..as would the same wattage of lighting…added bonus there makes ws look occupied…
                            #135333
                            Russell Eberhardt
                              @russelleberhardt48058
                              Posted by jason udall on 12/11/2013 15:05:46:
                              . . . or raise the temperature of the machine slightly above ambient. When I lived in the UK I just threw a dustsheet over the lathe and put a 50 W bulb in the stand. Never had any problem with condensation.
                              Of course you could always move to a warmer, dryer climatesmiley
                              Russell.
                              #135337
                              NJH
                                @njh
                                Jason U says " .…all insulation does is slow down the temp drop…" and this slowing down is really the key.
                                I have , as John (Bogs) advocates, a small thermostatically controlled oil filled radiator which I run in the months November to April. I took a deal of trouble to insulate my workshop and have monitored internal and external temperature, dew point and heating used on a daily basis for some years. As an example the total cost of heating for 2012 was £15.57. It works BUT you must have good insulation – without it there will be rapid swings in temperature with consequent condensation as the dew point is crossed. A dehumidifier may well be useful to remove some of the moisture from the air – if the air is dry then there IS no moisture to condense. I don't know the relative costs of heating against dehumidifying but a warmer workshop is nicer to work in and the heating helps with that!
                                Norman
                                #135338
                                  Posted by Jerry Wray on 12/11/2013 13:34:53:
                                  David,
                                  JerryNotts
                                  Jerry,
                                  Unless the room is almost sealed [unlikely, if it's a garage] you would be trying to dehumidify the Planet … in which case "Large" = "Unimaginably Large".
                                  Much more realistic to do what I, and others, have suggested; provide some local warmth around the machines.
                                  There will probably still be condensation somewhere in the room … but you can move it to where it does less damage.
                                  P.S. What is the construction of the garage, and do you still use it as such?
                                  #135340
                                  Sub Mandrel
                                    @submandrel
                                    I have a well insulated workshop, and over the past eleven winters years, heated or not, I have only suffered enough rust to cover an after eight.
                                    I have a heater I put on anti-frost in very cold weather, or to heat it up when I go in.
                                    nigel jones 5
                                      @nigeljones5
                                      I bought a b&q dehumidifier oft ebay – works brill!!
                                      #135364
                                      wendy jackson
                                        @wendyjackson
                                        Hi, I have insulated the workshop which helped.but last year there was signs of rust on machined surfaces. This year I added a small dehumidifier plumbed to release the water outside.at the begaining of using the dehumidifier water was pouring out most of the day.these days next to nothing.no more rust, and the newspaper always forgotten remains dry.the cost of running is very low as the machine only starts up if needed.michael
                                        #135365
                                        Mark P.
                                          @markp
                                          I tend to open a window and put a wooly on. Also I slap oil all over the place.
                                          Mark P.
                                          #135367
                                          daveb
                                            @daveb17630
                                            Be careful with the dehumidifers, dry air can cause irritation of the nose and throat and mummification of everything else.
                                            #135372
                                            David Clark 13
                                              @davidclark13
                                              Hi Jerry
                                              Large yellow one from Argos.
                                              Did a three bedroom bungalow.
                                              regards david
                                              #135373
                                              wendy jackson
                                                @wendyjackson
                                                Posted by daveb on 12/11/2013 19:55:37:
                                                if the room, workshop what ever is a sealed place then yes. most workshops including mine are far from it. the dehumidifier is only plugged in last thing as I leave so never in anyway harmful. michael
                                                #135374
                                                ronan walsh
                                                  @ronanwalsh98054
                                                  Posted by Mark P. on 12/11/2013 19:50:00:
                                                  Mark P.
                                                  I was doing that, but the oil tended to emulsify and act like a poultice on the bare metal. strangely i went out to the shed today and the machines were fine , no condensation to be seen, the uni-bond humidity absorbers did have some water in them though.
                                                  The shed itself is the usual cavity cement block construction with concrete floor. I wouldn't have built it like that personally, the father built it and its not a good job.
                                                  #135379
                                                  Steve Withnell
                                                    @stevewithnell34426
                                                    There are two problems with de-humidifiers – quite expensive to run and the typical ones don't work at low temperatures. They work well at 20C and pretty much not at all below 5C. I found it easier to stop heating the workshop and to keep machines covered up and things like chucks etc in zip lock bags. Keeping chucks in bags aslo keeps any avoidable dirt out.
                                                    One thing that will cause condensation is the sun streaming in on a cold winter's day. Everything warms up, sun goes down, condensation forms.
                                                    #135381
                                                    ronan walsh
                                                      @ronanwalsh98054
                                                      Posted by Steve Withnell on 12/11/2013 21:09:01:
                                                      I had wondered about the effect of a large window (which it has) on the condensation situation in the shed. Natural light is so much nicer to work in than artifical light though.
