Posted by here again on 07/02/2016 08:25:44:
I keep getting' problems with certificate'
As far as I can see its because some org or other doesnt approve of AVG , maybe because itsfree? Dont know whether to use or not
AVG won't cause certificate problems. It's OK to use it.
If only one site is causing certificate errors then the fault is at their end. Don't trust the site until they fix the problem.
If you are getting certificate errors from many different websites then a common cause is that your computer's internal clock is wrong, probably because the BIOS battery is dying. Although the clock should be automatically corrected by an internet time server there will be a period during which strange and confusing things happen. The clock goes wrong again when the machine is switched off.
Edited By SillyOldDuffer on 10/02/2016 21:39:35
