Posted by Roger Hart on 13/08/2019 14:37:08:
Sorry if this is a bit simple minded, but do wind generators generate 3 phase mains that is synced to the grid or do they generate dc which then feeds a big inverter synced to the grid?
The reason I ask is that if directly synced to the grid then each wind generator has a complex problem matching wind speed to its output. Indeed keeping a few hundred all synced up and matching output looks a bit difficult.
One the other hand if they actually generate dc then I can't see that wind speed would affect the overall output frequency, the inverter(s) sort that out.
So how do they work?
Various ways of doing it; a simple scheme might just synchronise naturally with whatever the grid is doing. Not very efficient, mechanically stressful during gusts, and the turbine has to cut in and out whenever the wind speed is too low or too high. Early technology.
Small turbines often generate DC converted electronically to AC with an inverter. These have no problem matching to the grid over a wide wind speed range. By using a permanent magnet generator the need for a gearbox can be eliminated, making conversion nearly 10% more efficient. Unfortunately big invertors are pricey.
To keep cost down, big turbines – which can be 150MW plus per unit – drive a three phase generator fitted with an extra set of windings. An electronic controller matches the output of the generator to the grid by rotating and altering the amplitude of the magnetic field inside the extra windings. Again the turbine has to be cut in and out whenever the wind goes out of tolerance, but the more advanced controllers can manage restarts within several cycles.
Other schemes available and I don't think there's a single preferred generator design in view yet. What's suited to a big off-shore generator with reliable wind wouldn't suit a small unit on an hilltop where inland ground turbulence causes lots of variation. But, because the electronics are getting more power capable and considerably cheaper, I'd guess the straightforward inverter approach might become universal one day.
