Gloss to Flatt
Gloss to Flatt
Home Forums General Questions Gloss to Flatt
  • #26336
    Boldminer
      @boldminer
      painting
      Boldminer
        @boldminer
        Can anyone tell me if there is a way to alter a gloss finish paint ( supplied wrongly by a UK supplier to me here in Thailand) to produce a Flat finish. The main cause for concern at the moment are the wheels of the loco that have already been painted. Can I simply spray over them with a 'flat' lacquer and would this be OK on the boiler? Your replies would be greatly appreciated.
        #384470
        Alan Waddington 2
          @alanwaddington2
          Depends on what type of paint it is. I used to use xylene based industrial paint for a particular job and for a silk or matt finish the supplier just added a percentage of a flattening agent to the gloss at mixing stage.
          For small jobs using rattle cans from the motor factors i have succesfully used colour with a matt laquer over the top to get a flatter finish.
          You could maybe try a small test piece first to check for finish or reaction.
          Edited By Alan Waddington 2 on 08/12/2018 06:30:34
          #384471
            Provided the clear coat is compatible with the base colour then that should be fine, I do it a lot particularly on the Hit and Miss engines where I use a fuel proof clear in either gloss or satin. Unlikely in your case but the clear can give a slight yellow tint if applied to white.
            #384475
            vintage engineer
              @vintageengineer
              You can getting flatting agents for oil and cellulose paints.
              #384659
              Boldminer
                @boldminer
                Thanks to all that took the time and trouble to reply to my query. I do know of a place here in Phuket where I can buy a matt aerosol so that is the route I’ll try first. Regards, the Boldminer
