If you are seeing tight spots and loose spots in the travel of a slide then the gib or slide is wrong. trying to design a solution to something that is wrong is not going to improve the basic fault. There should be no tight spots and if there is then you need to find out where they are and which surface of the mating sliding parts are in error. Gib strips are there to enable the mating of parts to slide easily and to some extent adjust the degree of the 'slip' and basically must be flat. The mating part to the gib must equally be flat but must allow a very thin film of oil to prevent 'sticking' or tight spots. This oil retention is normally provided by one or both sliding surfaces having very small hollows usually provided by scraping or in some cases a rough grind. Scraped surfaces are the perfect answer but like most things require a lot of skill and time to make well. Then comes the fixing of the gib which can be, as seen on many imports, by a screw at each end of a taper gib or possibly by a simple flat gib of constant thickness which is held in position by a series of screws (Myford). Personally, I prefer the Myford approach but often after removing either style of gib it is not always straight which is due to the stresses inherent in the gib material and manufacturing process. This does not impede the function of the gib because the screws 'bend' the gib flat to its mating slide.
The problem you describ is only cured by examining the flatness and ability for oil retention to all the slide mating surfaces. The difference between a quality precision made slide comes down to the accuracy of these surfaces and often requires a lot of fitting time or expensive machinery to accomplish this. As an owner of both a Myford and import machines the latter all required remedial work to achieve a silk-like sliding motion and thankfully, the use of a gib strip provides the ability to scrape or re-work the surfaces without losing accuracy to the functional slide.
Hope this helps – you might find it interesting to research the various past discussions about the design of the gib screws and gibs, I think the dome end shaped screws provided the best result in the case of dovetail slides to make very fine adjustments to the gib pressure. These solutions are not likely to be found on import machines but can be introduced to give top quality results.
