Sean,
The motor you intend to use the switch with, are there seperate terminals for the start winding and run windings?
If the answer is yes, then the simplest way to having a bi-directional motor is to use a dpdt switch for the start winding….
If this is so, I'll sketch you a drawing in how to hook up said switch along with the nvr switch….
