Fiat 702 Tractor
Fiat 702 Tractor
Home Forums General Questions Fiat 702 Tractor
Viewing 14 posts - 51 through 64 (of 64 total)
  • #133467
      Looking good Gray, will you use a valve seat cutter to true the surface when the seats are pressed in or just go straight to lapping to the valve?
      J
      21C105
        @21c105
        Posted by Graham Meek on 07/10/2013 08:57:05:
        In light of recent events else where on the Forum I shall no longer be posting any developments on this project or any further comments on this Forum, instead I intend to concentrate on my writing.
        Gray,
        Edited By Graham Meek on 07/10/2013 08:57:53
        Bit confused as to what is happening here. Could somebody kindly enlighten me, please ? Thanks
        #133478
        Sub Mandrel
          @submandrel
          Totally awesome, Gray, as the young folks say.
          Ian S C
            @iansc
            Gray, thanks for your reply on the valve guides, I don't imagine the motor will do that many hours of running over a great number of years, in fact that it runs is good enough for a master piece like this, and a glass case for it to live in. Ian S C
            #134315
            Ian S C
              @iansc
              I was just thinking, it's going to be something that should not be put on a shelf in the workshop, only to be bought out every now and then, but should be on display. The glass case idea was just to save dusting. Ian S C
              #134330
                This is what you need Gray
                #134338
                Sub Mandrel
                  @submandrel
                  is that what they call a 'glass case' model?
                  dave greenham
                    @davegreenham19379
                    Hi Gray.
                    Im quite willing to nip over and take it off your hands.I can find somewhere to display it for you
                    regards
                    dave
                    #134386
                    Ian S C
                      @iansc
                      That looks nice Jason, hope no one uses the chimney as an ash tray. Ian S C
                      #134394
                      Sub Mandrel
                        @submandrel
                        Hello Gray,
                        Your wish is my command: GRAY'S WISH GRANTED
                        blowlamp
                          @blowlamp
                          Gray.
                          I can't help with the size (about 2mm diameter from memory?), but if the Mamod drive spring isn't quite the right size, you might well be able to find something suitable from a lip-type oil seal. Garages tend to keep leftovers from gasket sets and they often have these seals in them.
                          The fan appears to be chain driven from the above picture, so what about a fusee chain for a clock or watch?
                          Martin.
                          #134531
                          Sub Mandrel
                            @submandrel
                            I measured one at 1.97mm or 0.0775".
                            I can send you one if you need it.
                            blowlamp
                              @blowlamp
                              Posted by Graham Meek on 03/11/2013 18:32:56:
                              Hi Martin,
                              I appreciate your thoughts on the source of the spring driving band from old Oil seals, unfortunately on the original tractor the driving belt was a segmented type as it had to passed through two cast in apertures in the radiator assembly to get to the crankshaft pulley before being joined to go over the fan pulley.
                              As Mamod drive bands can be had in various lengths that can be cut and assembled in situ I thought these would be ideal, otherwise I would have to make a removable portion from the radiator assembly. I know I could have used a plastic cord, but the joins never come out to my expectations, where as the Mamod type just screw into each other.
                              Gray,
                              Hi Neil,
                              Many thanks for the information, I had a feeling it was 2 mm but I was not sure, I can obtain them locally as Forest Classics are just down the road. It was just that I wanted to get the design finished today if I could and now I can, thanks.
                              Gray,
                              Gray.
                              The reason I mentioned the garter springs from oil seals is that they join in exactly the same way as the Mamod springs, but come in various diameters, one of which I though may have been suitable if the width of the Mamod offering was not right for your application.
                              Martin.
                              #134577
                              Sub Mandrel
                                @submandrel
                                That puts modern plastic fans to shame.
