The thread 'Arc Euro ER16 runout' got me thinking. Thought I'd start a new thread, rather than hijack that one.
I've just looked at the Schaublin collet chuck that Emco supplied for the FB2 milling machine. I'd rather taken it for granted before – it just did its job, apparently accurately. But now I'm wondering… are these things designed optimally? Clearly, axial alignment cannot be taken for granted and the availability of 'forcing clamps' (dunno what they're really called) to tweak cutter alignment suggests that concentricity may not be as reliable as one would want.
I assume that the collet is aligned by the taper in the body of the chuck. If the collet collapses symmetrically (and is made concentric), alignment should be determined by the collet chuck's accuracy. But this assumes that the collet is not able to be deflected radially as it is tightened. Is this assumption valid, in practice? There are two complications…
Firstly, the short taper on the collet's nose mates with the taper in the closer (nut). The closer is threaded to the body with a 'normal' V thread, so it is 'centred' by the thread. If there is a malalignment between the closer and the body, the closer's taper and the centring action of the thread may fight each other, resulting in a radial force on the nose of the collet. Wouldn't a 'sloppy' square thread (large radial clearance) be better? There would then be no chance of the closer exerting a radial force on the collet. (OK, we really need symmetrical spanner work, but that applies to the conventional design anyway.)
Secondly, for collets with extractor grooves, it might be that, as the closer collapses the collet, allowing the collet to settle deeper into the closer's taper, the closer's extractor (half-) ring 'bottoms out' on the collet's groove, and contact between the closer's taper and the collet nose's taper is lost. Also, the axial force would be off-centre. Wouldn't it be better for the cap to be able to exert only a reliably axial force? Why have a taper in the closer, or is it to ensure the greatest radial force is applied to the cutter at the collet's nose?
Perhaps I should just continue to take it for granted…
