Does the safety valve have to be above the water level in the boiler ?
Home Forums Beginners questions Does the safety valve have to be above the water level in the boiler ?
Viewing 12 posts - 26 through 37 (of 37 total)
  • #170362
    FMES
      @fmes
      Brian,
      The safety valve itself is on the outside of the boiler and if mounted on the top, is above the water line.
      Don't worry about the sprung part that is actually inside the boiler as it will mostly be in the steam space, and will not affect the operation of the valve.
      Only if you overfill the boiler, say, more than two thirds capacity, will there be a chance of the valve being able to pass high temperature hot water or 'Prime'.
      After all, they used to give this type of boiler for kids to play with dont know
      Brian John
        @brianjohn93961
        Okay, I understand now. I think it may be worth doing. I am still waiting for my step drills to arrive from China.
        #170374
        Bazyle
          @bazyle
          Posted by Lofty76 on 22/11/2014 12:54:44:
          You mean lots of Dads bought one to play with and used the kids as an excuse. angel
          If it weren't wet an miserable I might be tempted to give my traction engine a qick run. Instead I'm looking into the missing bits of an incomplete stationary one I bought two decades ago (for my nephew who is now married ).
          Thanks for supplying the link earlier Jason, it looks quite cute.
          #170388
          FMES
            @fmes
            Posted by Bazyle on 22/11/2014 16:29:16:
            Damn, sussed blush
            #170411
            Brian John
              @brianjohn93961
              And they used to give lead soldiers, firecrackers, slingshots and air rifles to kids to play with too
              Alas….no more !
              #170415
              Howi
                @howi
                Posted by Brian John on 23/11/2014 02:54:56:
                Alas….no more !
                Yup! Had all those, kids today don't know what they are missing.
                #170418
                  Fah! My daughter is a better shot than I am, although I'm better with a bow and arrow
                  Brian John
                    @brianjohn93961
                    I am back in Cairns now. The step drills arrived in my absence so the first job was to drill an 5/16 hole for the Mamod safety valve bushing ; the safety valve will also act as my filler plug when finished.
                    The step drill worked well ( thank you for the advice) however I did end up with a ''lip'' around the hole which extended 3mm down on the other side. It was a real pain to remove but it is all cleaned up now. I should have drilled from the inside to the outside of the boiler end cap as this would have made it easier to clean up.
                    Is there a trick to using step drills so I do not end up with this ''lip'' on the underside of the metal ? I have never used them before.
                    #171442
                    FMES
                      @fmes
                      Something like this **LINK** works very well Brian.
                      #171443
                        As its a step drill just turn it by hand or carefully with the drill from the other side and that will take the burr off
                        #171459
                          The deburring blades with handles make deburring easy. I am addicted to the cheap sets of four half way down here. or look out for the free mango handle and deburrer tip offer for ME subscriptions.
                            I'm liking this set from Tracy, a quick twirl of the CSK type one is ideal for deburring small holes and the little triangular scraper is good for getting them off cross holes drilled into a tube etc.
