Coolant pump and VFD
Home › Forums › Electronics in the Workshop › Coolant pump and VFD
  • #647810
    Michael Horley
      @michaelhorley72278
      Good evening all. Can someone give me some advice on wiring up the coolant pump on my recently acquired Bantam Mk1 please?
      I have a 3 phase motor running off a VFD but the coolant pump isn't connected, can I connect it up to the same terminals as the main motor? If so can I also wire in an on off switch?
      Thanks in advance.
      #32345
      Michael Horley
        @michaelhorley72278
        #647811
        duncan webster 1
          @duncanwebster1
          You could run a coolant pump using a capacitor, called a Steinmetz circuit I think. Described in the little book on electric motors part of workshop practice series
          #647820
          Robert Atkinson 2
            @robertatkinson2
            As long as the pump motor is much smaller than the main motor and the VFD is rated for more than the combines power of both yes you can connect the coolant pump in parallel with a switch. The main motor must be permanently connected to the VFD. If the pump motor is wired star (415 V) and the main motor has been changed to delta (240) I would initally leave the pump wired star and se if it produces enough flow for your use. Leaving it star will reduce the additional load on the VFD with the pump running. Make sure you use a 3 pole switch. While a 2 pole will work with normal 50Hz mains leavine one pole permanently connected to a VFD will cause an imbalance fo the high frequency PWM signal of the VFD. This can cause incorrect operation. damage to motor or drive and increased intereference.
            Stienmetz is also an option see https://www.js-technik.de/en/faq/detail/groupid/4/id/75
            Robert.
            #647846
            Andrew Tinsley
              @andrewtinsley63637
              Hello,
              I had the same problem with an ML7 and a "Myford" 3 phase 415 volt suds pump. The pump was in star and was easily reconnected into delta configuration. I used a 2 microfarad capacitor to configure the motor into the Steinmetz set up
              Worked a treat and i found that the 3 phase voltages were almost the same and were nearly 120 degrees in phase. The 2 microfarad capacitor was small enough to live inside the motor housing. So a very neat and practical way to run the suds pump off 240 Volt AC mains.
              Andrew.
              #647865
                Posted by Andrew Tinsley on 08/06/2023 11:16:46:
                Hello,
                Worked a treat …
                Andrew.
                Always worth putting figures on subjective statements like 'worked a treat'. When measured, Steinmetz connected motors perform significantly less well compared with running on a 3-phase supply:
                • At least 30% less power output
                • At least 70% less torque
                • 2-pole motors perform extra poorly, possibly turning not at all
                When they work Steinmetz connected motors are a convenient compromise, not the best possible engineering solution. The most likely gotcha is low torque, so more likely to perform acceptably on Suds pumps and similar applications that don't need lots of turning power.
                If Steinmetz connections worked well in all circumstances there would be no market for rotary converters and VFDs. More sophisticated approaches to 3-phase come with significant advantages, VFD's being extra tasty with speed control, torque boost, soft-start, and efficiency savings. But usually limited to one motor per VFD. On the other hand, if it works, simplifying a major rewire job by adding a small capacitor to an existing motor is fit for purpose and value for money. Just don't expect miracles!
                Emgee
                  @emgee
                  The coolant pump on my Bantam is 400v 3 phase working voltage but it has been used occasionally for many hours during the last 20 years with the capacitor method of connection to a 240v AC supply.
                  Emgee
                  #647868
                  Andrew Tinsley
                    @andrewtinsley63637
                    Hello Dave,
                    Sounds as if you are in one of your "be careful moods" Absolutely no one is talking about large motors and the deficiency of the Steinmetz system re reduced torque and power! A suds pump motor is way overated for the job it does. Your warnings of grief are most certainly over the top. If emgeee can use such a motor connected WITHOUT the Steinmetz capacitor and without reconfiguring the voltage from 415 to 240 volts Then your Jerimiah predictions are totally invalid.
                    I certainly would not try to emulate emgee, but a correct value Steinmetz capacitor and rewiring to 240 V is a totally logical thing to do without any drawbacks.
                    If I were suggesting the Steinmetz system for a 5 HP lathe motor, then your comments would have validity. Please don't put people off from modding a suds pump in the same way.
                    Andrew.
                    #647878
                    duncan webster 1
                      @duncanwebster1
                      Steinmetz worked for me on Ferret grinder. The motor manufacturers recommended. Not running it off a vfd, something to do with old motors and insulation, but we're quite happy with my solution.
                      #647879
                      Mark Rand
                        @markrand96270
                        If you are using the VFD just to generate 50Hz three phase then JFDI* and feed the suds pumpfrom the VFD as well.
                        If you are using the VFD for variable speed purposes, then use a capacitor.
                        * Just Flipping Do It! cheeky
                        Edited By Mark Rand on 08/06/2023 17:28:53
                        #647890
                        Michael Horley
                          @michaelhorley72278
                          Thanks for all your comments, I have ordered a 2mfd capacitor so I will try that first.
                          #647895
                          Andrew Tinsley
                            @andrewtinsley63637
                            Hello Michael,
                            If you are going to supply 240V Ac to your pump, it may be better to rewire the motor to a star configuration rather than the 440 V delta which it is at the moment. Be careful in selecting a capacitor. The usual motor start capacitors are electrolytic and won't last long before they go bang in a Steinmetz circuit. The type you need are non electrolytic types and rated at 400 V DC or near. These are the types found in Motor run capacitor circuits. Or in fluorescent lamp units (or any power factor correction usage, where it is connected across the mains)'
                            The 2 microfarad capacitor that I used was selected after a little experimenting. I wanted the 3 phases to be near enough equal in voltage and at almost 120 degree phase difference. A 2 microfarad capacitor will work on your suds pump , but it may not give the optimum results of equal phase voltage and 120 degree phase separation. Not that it is all that important. It should give you an operational pump running on 240 V Ac.
                            Andrew.
                            #647899
                            Michael Horley
                              @michaelhorley72278
                              Thanks Andrew. I had already ordered the 2mfd capacitor after delving through the net looking for Steinmetz so your previous post confirmed I was in the right ball park!
                              I have just checked and it is a motor run type so hopefully it will work.
                              #647917
                                Posted by Andrew Tinsley on 08/06/2023 14:12:20:
                                Hello Dave,
                                Andrew.
                                I plead not guilty M'lud!
                                After providing numbers showing the actual limitations of Steinmetz , I finished my post with:
                                On the other hand, if it works, simplifying a major rewire job by adding a small capacitor to an existing motor is fit for purpose and value for money. Just don't expect miracles! Is that really a Jeremiad?
                                All engineering is conditional, and most of it can be expressed numerically. Bridges, ropes, aircraft and ships have weight limits. Car batteries only contain so many ampere-hours, internet connections have bandwidth and latency restrictions. Threads have to be cut accurately or they won't fit. It's useful to understand the underlying rules.
                                In engineering, guesswork, hearsay, optimism and random experience are all low value compared with knowledge. It's why the forum is wonderful: others know stuff I don't. When something doesn't work, we can establish why not and what to do about it. Sometimes the answer is a lemon.
                                duncan webster 1
                                  @duncanwebster1
                                  Posted by Andrew Tinsley on 08/06/2023 21:22:46:
                                  Hello Michael,
                                  Andrew.
                                  Andrew,
                                  Are you sure you've got that the right way round? It conflicts with your earlier post, and I rewired my grinder to delta when I did it.
                                  #647921
                                  Andrew Tinsley
                                    @andrewtinsley63637
                                    Thanks Duncan,
                                    Must be old age, the motor should be wired for 240 Volts i.e. delta connected. goodness knows what I was thinking of.
                                    Andrew.
                                    #650010
                                    Michael Horley
                                      @michaelhorley72278
                                      Just to close this off, I used a 2mfd capacitor across two of the phases and 240v across one of those and the other phase. The pump works perfectly with a good strong flow.
                                      Thanks everyone.
