Colchester Headstock Sleeve
Home › Forums › Workshop Tools and Tooling › Colchester Headstock Sleeve
Viewing 25 posts - 1 through 25 (of 25 total)
  • #369285
    Alan Waddington 2
      @alanwaddington2
      My Student 1800 was missing the oft misplaced tapered Headstock bush for turning between centres. I bought one off ebay a few years back and popped it on a shelf…….came to use it today and of course it’s the wrong size dont know.
      Questions are.
      A- Does anyone have the correct one lying around they wish to sell? Or know where i might obtain one.
      B- Any idea’s what the one i have is off. Dimensions are 1.622” at the fat end. 1.500” at the thin end. 2.490” Long. With a 3mt oil upt middle.
      There are a few on ebay, but at least two which are advertised for my machine, clearly are not, so i’m a bit wary, twice bitten and all that.
      The hole in my headstock measures 1.766”,bit awkward to measure the far end hole, but approx 1.675” with the bush being around the same length as the one i have.
      #19057
      Alan Waddington 2
        @alanwaddington2
        #369290
        Simon Williams 3
          @simonwilliams3
          Now here's a knotty little riddle.
          My Bantam 2 has a bastard size taper up the head stock, which is rumoured to be MT4.5, or some such. It seems Mr Colchester didn't want us buying standard fittings so he made the head stock a funny size, though it may be something to do with the size of the bearings carrying the head stock. Mr Lathes.co.uk has got some comments thereon.
          Anyway I'd have assumed that your Student was the same, but it can't be. I made a bush for my Bantam, but it's 1.517 – 1.362 by 3.07 ins long.
          However, when I bought the lathe I was given what was supposed to be the "right" bush, which is much too large. Squirrel that I am I've kept it, and it is 1.809 – 1.656 x 3.036 long. All these dimensions measured with calipers, so somewhere handy but not precise. While those dimensions aren't exactly what you've shown above, they look something useful.
          You are welcome to try the second bush and see if it is what you are looking for, send me a PM with your address and advise so on here and I'll pop it in the post next week.
          Hope this works! Rgds Simon
          #369291
          Alan Waddington 2
            @alanwaddington2
            Posted by Simon Williams 3 on 27/08/2018 15:31:55:
            That’s very kind of you Simon. Interestingly the dimensions you have given are remarkably close to one on ebay. I suppose the slightly larger fat end could account for the bush sticking out a bit. Will drop you a PM.
            #369301
            duncan webster 1
              @duncanwebster1
              When I had a Chipmaster with the taper thing missing I convinced myself it was Jarno, which is as
              Doesn't help you in finding one of course, but I never needed one, for between centres just chuck a bit of bar i the 3 jaw and turn a point on it
              #369306
                It sounds like it might be the 'thin end' of an MT5 taper. 1.5" is the fat end of MT4.5 so it can't be that.
                This thread suggests the Student has an MT5 taper: /www.model-engineer.co.uk/forums/postings.asp?th=104715
                If that's the case you just need an MT5 to MT3 reducing sleeve – or an MT5 centre.
                Nigel Bennett
                  @nigelbennett69913
                  Yes, it's 4.5MT. It's fairly common, as the Boxford X10 series lathes (280, 330, etc) with the D1-3" camlock have them, as well as the Chipmaster and Bantam lathes. I don't think the Harrison D1-3" camlock lathes are like that.
                  I suppose the thinking was that 4MT was too restricting and 5MT too big for the spindle.
                  #369314
                  Alan Waddington 2
                    @alanwaddington2
                    Good call Neil, just tried a 5mt -1mt reducing sleeve i had lying about and it seems to fit perfectly. No good for my purposes, but proves a point. 👍
                    #369323
                      The thanks are due to Les Jones 1
                      #369368
                      John McNamara
                        @johnmcnamara74883
                        Hi Alan
                        My lathe did not come with spindle taper plugs
                        I made two, one Morse and one NC taper at the same time. I did not use a chuck or centres.
                        I posted posted the method here here a while back.
                        Alan Waddington 2
                          @alanwaddington2
                          Posted by John McNamara on 28/08/2018 00:22:18:
                          Hi Alan
                          Great Job John, thanks for posting…….however i seem to be getting further from the job in hand evey time i go in the workshop, so this time i will be buying rather than making.
                          No idea if it’s just me, but nearly every job i do requires me to either make or buy something to fix an issue before i can start the job i initially wanted to do.
                          #369456
                          Simon Williams 3
                            @simonwilliams3
                            Alan – I've sent you a PM.
                            Rgds Simon
                            #369799
                            Alan Waddington 2
                              @alanwaddington2
                              Just to update this thread, Simon kindly sent me the bush he had, and it fitted perfectly. (Thanks Simon)The taper is indeed 5mt, but the fat end is larger than a drill sleeve so it sticks out of the headstock a little way.
                              I therefore have a bush going spare. (My ebay purchase)
                              So if anyone can identify it, and make use of it, the same deal as Simon did for me will apply.
                              Let me know your address and i will post out at my cost.
                              If it suits your needs, you make a minimum donation to charity of £10
                              If it does not fit, you return to me, or someone else who’s machine it may fit.
                              These tend to be advertised between £30 and £70 on ebay
                              Edited By Alan Waddington 2 on 31/08/2018 14:12:17
                              #396336
                              Richard –
                                @richard-3
                                Hi Alan, have you still got the bush, my Harrison is reported to be 41/2 MT
                                thanks
                                Richard
                                #396344
                                Alan Waddington 2
                                  @alanwaddington2
                                  Posted by Richard – on 14/02/2019 22:21:12:
                                  thanks
                                  Richard
                                  Hi Richard, yes still on a shelf, PM me your address and i will send it to you.
                                  #396345
                                  Pete Rimmer
                                    @peterimmer30576
                                    Without drawing it up in CAD your adapter sound awfully close to #13 Jarno taper.
                                    #396347
                                    David Standing 1
                                      @davidstanding1
                                      Posted by Pete Rimmer on 14/02/2019 23:40:04:
                                      There are three different bush sizes referred to in this thread, which one are you referring to? wink
                                      #396361
                                      Richard –
                                        @richard-3
                                        Alan sent pm
                                        #396386
                                        Howard Lewis
                                          @howardlewis46836
                                          Jarno tapers all have the same taper, 2 degrees 15 minutes.
                                          A 5MT / 3MT sleeve should be available from someone like Warco or Chester, since the BH600 and Craftsman are 5MT Mandrels, and came with a sleeve. Possibly, some of their successors did as well.
                                          #396398
                                          Pete Rimmer
                                            @peterimmer30576
                                            Posted by Howard Lewis on 15/02/2019 10:47:44:
                                            Are you sure? I'm no Rachel Riley but I get 2.8664 degrees included angle.
                                            #396420
                                            Howard Lewis
                                              @howardlewis46836
                                              Peter!
                                              Quite right
                                              Taper according to Engineers Edge is 1;20 which I make 2.8624052 degrees (2 degrees 51.44314 minutes)
                                              Shouldn't have relied on my memory, from the last time that I turned one!
                                              #396425
                                              Howard Lewis
                                                @howardlewis46836
                                                PS
                                                Would be very surprised if the mandrel taper was a Jarno. Within my limited knowledge , would expect most Lathe mandrels to be a Morse Taper.
                                                Pity that the Morse Taper varies from size to size, unlike the Jarno.
                                                #396440
                                                Pete Rimmer
                                                  @peterimmer30576
                                                  One of my lathes is Jarno 12. I wish I could find an adapter for it.
                                                  #396498
                                                  Frankiethepill
                                                    @frankiethepill
                                                    My old Bantam mk1 takes a Headstock sleeve adapter MT4 – 3 (supplied by RDG) and all seems to fit well. Total cost under a tenner..
                                                    #396500
                                                    Hopper
                                                      @hopper
                                                      With the difference between a Morse and Jarno taper being in most cases within .001" to .002" per inch, it's quite possible that the one will fit the other in a short application like the headstock collar, without the mismatch being noticed?
