Posted by Speedy Builder5 on 13/04/2017 11:36:49:
Ian, it wasn't a problem of finding Citric acid, it was the problem it caused with lead solder. Unfortunately Neil's suggestion of meths for cleaning up the solder joint after the citric damage didn't work either. In the end I had to resort to mechanical cleaning before using an active flux. The solder I used was a flux cored (Multicore) solder 60% Tin 40% lead (I happened to have a lot of that to hand). For the second fix, I used some 50/50 unfluxed solder and finally in one awkward corner used form lead free to 'Caulk' up as it has a better gap filling property.
BobH
I'm an advocate of Citric, particularly hot Citric, which is every bit as effective as other more powerful acids.
Some of those more powerful acids don't benefit (as much) from heat, not that you would want to use them that way anyhow.
I've only ever used acid pickle on hard soldered joints. Mainly because the borax flux is so tough to remove.
For soft soldered joints, especially with acid flux, you can just use warm water to clean up. For that I usually use Fry's Powerflow flux and it just works very well indeed.
If you use Rosin cored solder, then you do get a residue. Meths is a disaster for that. It won't shift anything and you get a white deposit which looks really gross. The best stuff I've ever come across for rosin cored solder flux removal is from Electrolube. It's in an aerosol, called LFFR (Lead Free Flux Remover). It even smells fairly nice. Don't breathe it though, it's Cyclohexane. I've no idea what that is, but rest assured that one day someone will recognise it as being bad to small furry nylon bears.
Farnell Pt. No. 1098276
It will lift the sticky deposits. All you have to do is make sure that the solvent has been wiped away before it evaporates. Wherever the solvent evaporates, the Rosin residue will be left. The aerosol has a brush nozzle. You give it a squirt, mush it in with the built in brush, and then dry the solvent with a paper towel. Job done.
Edited By Andy Ash on 14/04/2017 23:00:04
