Carbide PCB drills and router bit sources
Home Forums General Questions Carbide PCB drills and router bit sources
  • #361084
    Peter Harrison 2
      @peterharrison2
      It has been a couple of years since I was able to get to an engineering show. A regular supplier was someone selling solid carbide drill, milling and routing bits. All on 3.2mm shanks, many with indexing collars. I assume these can from PCB manufacturing and were swapped out after a certain number of hour running.
      Now I need some more but I cannot find this, or any other supplier, through the magic of Google.
      So – does anyone have a website address of this or another supplier of these really useful cutters?
      Peter Harrison 2
        @peterharrison2
        #361092
        Joseph Noci 1
          @josephnoci1
          Peter, Maybe not local to you, although Banggood may have a dispatch warehouse in the UK I think – Anyhow, take a look here:
          I use the 15deg 0.1mm engraving bits for isolation routing of the copper tracks on PCB's – buy them in packs of 10, and generally get 2 or 3 duds in the pack – not ground properly and raise horrid burrs, but the price for a 10 pack can't be beat..
          The drill bits and routing bits I have also purchased quite a number of – found no duds there so far..
          Shipping to/within UK should be good – to me in Namibia is mostly pot-luck…
          Joe
          #361118
          John Rudd
            @johnrudd16576
            Try ESR electronics in Cullercoats….
            https://www.esr.co.uk/electronics/products/frame_pcb.htm
            (just up the road from me…)
            Edited By John Rudd on 07/07/2018 11:40:32
            #361128
            John Haine
              @johnhaine32865
              Loads of suppliers on eBay.
              #361140
              richardandtracy
                @richardandtracy
                The 1.5mm router bits are useful for very tiny milling. Even did a pen decal logo into wax on my CNC router with a 0.3 mm cutter. Got all mine from various e-bay sellers at £5 to £7 for 10, so not pricy even if they take a month to arrive.
                Richard.
                #361146
                Peter Harrison 2
                  @peterharrison2
                  Good links. Thank you.
                  ESR had slipped my mind. Not seen them for a while.
                  I have had cutters from Ebay and they have been fine – it can be a bit f a lucky dip for delivery and getting exactly what you want among the endless choices.
                  Finding the magic search term is often the key.
