Can auto darkening welding helmet capsule be restored.
Home Forums General Questions Can auto darkening welding helmet capsule be restored.
  • #554370
    Windy
      @windy30762
      Can auto darkening welding helmets capsule be restored..
      After some years decided to practice Aluminium Tig welding today.
      I have a Parweld helmet that is as new I hardly used as not fine enough for low amp welding that I was doing on my flash steam stainless generators.
      Also a SWP that was great for welding with a few amps.
      The auto capsules are not working any chance they can be made working again.
      Did get an odd darkening but very rare..
      They both are hardly used I know there are some cheap solar ones on Ebay.
      If I can repair them easily would prefer to do that..
      Edited By Windy on 16/07/2021 20:37:40
      Windy
        @windy30762
        #554371
        Anonymous
          Flat batteries?
          #554372
          Joseph Noci 1
            @josephnoci1
            As Andrew said, probably the batteries, and most of these cheap helmets don't allow easy battery replacement – I had two such and did cut open the module – there were two lithium cells, in series, with the center tap also connected so seems like it used a split supply. Did that about 7 months ago, and this weekend the helmet is playing up again..
            This helmet also has small PV panels, but as I don't do much welding, the helmet sits in a box so no sunlight and no welding UV and it appears the quiescent current is not insignificant.
            I again replaced the batteries, but with two D Cells, duct taped to the top of the helmet..
            Joe
            #554374
            peak4
              @peak4
              If your local store has any left, Lidl had some on offer recently, which may work out easier.
              I've not tried them, so I don't know the quality
              Bill
              #554380
              Windy
                @windy30762
                Have jumped the gun the parweld has mainly been in its box for ten years its manual says the built in battery will only last 6 years.
                After being in the light all day its working again.
                The 10 year old SWP has started working again after leaving near when I practiced a few hours ally Tig welding.
                #554456
                Dave Halford
                  @davehalford22513
                  The SIP basic £40 one has a grinding option which switches the battery off. The battery is a CR3032 car key fob type. If it sees welding flash it still darkens.
                  #554461
                  Jim Smith 8
                    @jimsmith8
                    It will be the batteries. I had 2 Chinese that went the same way. The first had a draw for an AAA cell but the cell had been in too long and I had to clean up the terminals. The second had a coin cell battery inside which I replaced and neither helmet is now going to land fill.
                    During the helmet recovery process I discovered in addition to the electronic auto shut off, my darkening control knob had a switch on the end and when off, nothing drains the battery. I now remember to turn it to the off position.
                    #554484
                    Andy_G
                      @andy_g
                      Posted by Windy on 16/07/2021 20:35:37:
                      If they are the type with the small solar cells on the front, I believe they can sometimes be 'kick started' by leaving them in the sun for a few hours.
                      I have one of the cheap supermarket ones (Aldi, I think) with 2 arc sensors and while it is/was fine for stick welding, it wouldn't reliably stay dark with low-ish amp TIG. (A relatively inexpensive 'Tacklife' branded one with 4 arc sensors did work OK, however.)
                      #554493
                      Dave Halford
                        @davehalford22513
                        Posted by Jim Smith 8 on 17/07/2021 17:06:40:
                        Otherwise known as grinding mode smiley
