Thanks Bob, as a compromise I try to hold my breath to reduce gas consumption to 0 !
When one looks at the range of skills from novice to highly skilled and equipment from cheap and nasty to top of the range that one sees on here and having used some of the lower end of market MIG welders both given to me by folk who gave up trying to use them, and having bought a BOC Autolynx back in the 70s that I still use and claim as probably the best smallish MIG ever made, and also a large 375A industrial unit I can claim some skill and knowledge.
Industrial processes carried out with poor equipment and little skill are likely to end in disappointment at some expense.
Would it work ? On the basis of the information given, I would say NO ! You will note that I said 1.2mm wire and I described the feeding arrangements, a torch fed gun could use thinner wire but flux cored ? A domestic MIG is highly unlikely to be able to use wire above 0.8mm. It is the feeder/torch that lets cheap machines down ! Then there is the current needed ?
Be very wary of adverts claiming to do the seemingly impossible eg the soldering iron that was a laser cutter/welder !
Good luck. Noel.
