Hi all I am making an end silencer for an air rifle and I have joined the 2 pieces of metal together the top piece is steel and the bottom piece is aluminium. It has bolts securing it but I was wondering is there anything that’s like a mastic or filler that I could run a small bead of it along either side so that the screws in between can not be seen
JB weld, 2 part epoxy filler, P38 auto filler, Gorilla two part metal filler ( Dries grey  to name but a few, silicon sealant may do it but I've only seen it in clear, white, black, brown, usual disclaimer applies.
There is a polyurethane filler made for car body repairs, which is much stiffer than silicone, sticks like stuff and blanket, and unlike silicone is designed to be painted. As you only need a few inches rather than a whole dent-full, you might get a couple of squirts for a pint of ale at your local body shop.
Cheers, Tim
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
