Thanks for all your replies chaps. JohnS – I actually asked myself (such is your influence) what the Bodger's Lodge answer to my question would be, and came up with pretty much what you said. However, I'm not rich enough to sacrifice blades at 26 quid a pop in the interest of experimentation, still less risk knackering the saw, hence my question!
It sounds like I probably shouldn't try cutting steel on this saw, tho ali should be OK. I really don't want to get involved in major mods such as fitting a gearbox. Maybe the Burgess, if and when it arrives, will do the business. What I actually want to do is cut profiles in maybe 6mm steel plate to make supports for column radiators. They could be bought of course, but I need 6 and at 35 quid each, and – well – no. There are many other ways to skin this particular cat, but I'm sure you know how it goes, you get a new toy for a particular (in this case woodworking) purpose, then start thinking what else it might do…..
Thanks again for your replies, Rob
Edited By Robin Graham on 07/03/2016 02:16:38
