Super-Fine Feed Change Gear for a Mini Lathe
Home Forums 3D Printers and 3D Printing Super-Fine Feed Change Gear for a Mini Lathe
  • #31512
        I've put an STL for a 100-tooth Mini Lathe changewheel up on the web.
        I'll confess, I haven't used them yet, but with 20-t gears you will get a 25:1 reduction instead of the normal 16:1. This reduces the feed to 0.0025" or 0.06mm depending on whether you have an imperial or metric leadscrew.
          Don't have a mini lathe but would printing one 100 and one 127 fit and then also give you a route to imperial/metric while you are about it.
          #283749
            You can use a 127, but it will be huge, using a 63 works just as well for all practical purposes.
            Alan Vos
              @alanvos39612
              Now that 3D printing is an option, change gears could be a smaller module, more teeth in the same space. With suitable design software and due consideration of the load the smaller teeth can handle of course.
              #283883
                Posted by Alan Vos on 12/02/2017 15:58:51:
                Alan,
                I'm not sure how small a module printed gears can realistically be, without losing the tooth profile.
                Early last year, John Stevenson kindly printed a 127 tooth change-gear for me at 32DP [Module 0.8].
                This was a 'demonstration of concept' rather than a production component, but it is evident that the profile of the teeth was limited by the nozzle diameter of the printer.
                Neil's file may be more sophisticated than the one that John used, but I think this might serve as a caution.
                  I printed a 0.5 mod gear for a forum member which he used successfully to fix a school projector. I think you can see the profile of this gear is OK, even on the small teeth. It runs fine with a commercial 0.5 mod gear.
                  I'm printing a similar one right now as a spare for my scope drive – 0.5 mod, 108 teeth. The first run had a poor profile, which I traced down to the filament being oversize (1.82mm instead of 1.75mm) so too much filament was being extruded. The replacement looks as though it's going to be better.
                  #283932
                    Good news yes
                    Alan Vos
                      @alanvos39612
                      Thanks for those two examples. I should have added "and the right 3D printer". Personally, interesting as they are, I'm hanging on to my money for now. 3D price/performance continues to improve. For tpi threads, the 'close approximations' have proved good enough for the few I have needed, or am likely to need.
                      #284019
                      Ed Duffner
                        @edduffner79357
                        [Beginner question]
                        Could a change gear be formed in delrin/acetal by gently heating the edge of an acetal blank and running against a metal gear then allowing to cool as it continued to rotate? If it works, the teeth would be long but could the OD then be turned to give root clearance?
                        Ed.
                        #284026
                          Posted by Ed Duffner on 13/02/2017 19:09:18:
                          [Beginner question]
                          Ed.
                          Interesting idea, Ed.
                          The scope gear has come out very well, I had to print it twice as the on first print the bottom layer was 'squished' too wide. I reduced the first layer extrude to 0.9 of normal and printed on a raft and got a very nice gear.
                          Alan – the Dremel gives top-notch prints for about £1K, but as it's going back I've ordered a decent Prusa I3 kit. They take more setting up but are capable of excellent results once sorted.
                          #284030
                            I can't see any great objection, but I have a gut-feeling that it would end up being more effort than it first appears.
                            That might be a first ! … Neil and I started our replies with the same phrase
                            My post was interrupted … I was writeing it during the adverts in WRC.
                            Edited By Michael Gilligan on 13/02/2017 19:54:38
                            #285038
                            Chris_C
                              @chris_c
                              Neil, I believe I had a very quick chat with you about 3d printed changewheels at the Brooklands show last year. As it was a very quick chat indeed and as everyone else here wasn't around, the main point is that I have a 3D printed changewheel that has been in the gear train for just over 2 years being used as a fine feed and shows no signs of wear.
                              The downside is that it is not an extruded material print, it is a UV cure resin as I have access to that printer, but the involute profile is very good indeed.
                              At the time I had restored a 1930's Ideal flat belt lathe and had a list of missing changewheels from my set, so I printed those and a 63 tooth (which is the one shown in the below photo and youtube link) with the view of getting them cut from cast blanks. A parameterised model was made which takes DP, tooth count, wheel thickness, bore and keyway size so by editing each of those the set was made and being printed within 10 minutes of finishing the model. No finishing of any kind was needed, all gears fitted onto the lathe and mesh well as printed. They have been such a success that I no longer intend to replace them, even gear oil on the rest of the train doesn't seem to have worried them.
                              Happy to get some better close photos of them if there is any interest
                              #285040
                                Hi Chris,
                                Some photos and short description would be good for MEW, especially if you briefly explain the UV cure process.
                                I've had emails from two people who have used the 100T gears and found they work fine too. they are a bit big for the standard gear cover but fit on an unmodified banjo.
                                  Very interested, Chris
                                  Close-up photos … Yes please
                                  P.S. could you please let us know the D.P.
                                  Edited By Michael Gilligan on 19/02/2017 17:33:07
                                  #285052
                                  Chris_C
                                    @chris_c
                                    Michael, these are 16 DP for an idea of size. Photos aren't great, not much light in the workshop so depth of field is a bit shallow but it shows the required detail in certain areas. I've added high res versions so they can be zoomed into.
                                    High res link: **LINK**
                                    This one shows the lack of wear on the teeth given the use. Its sharp enough to see the tooth profile at the top of the gear by the cast one.
                                    The test is just visible in that, though it didn't come out super well in real life either, but it lists tooth count, dp and pressure angle.
                                    High res: **LINK**
                                    The machine that made them is an Objet 30 Pro by Stratasys (**LINK**), so rather than material being a plastic filament melted and positioned by a CNC head, resin is deposited much like an ink jet printer and cured with a U.V lamp. I imagine there must be companies offering the services of machines of this kind, but as I have access to it haven't looked into them I'm afraid.
                                    Hopefully there is enough sharpness to show the tooth profiles in the high res photos.
                                    Neil, it you think it would be of interest to people then certainly, I can do some better photos with natural light.
                                    #285055
                                      Many thanks, Chris … Very impressive.
                                      I fairness to JS though; I must emphasise that the blue one he printed for me was:
                                      (a) 32DP, and
                                      (b) produced on a much less sophisticated printer,
                                      John Stevenson 1
                                        @johnstevenson1
                                        I must admit that the quality of the gear I did for Micheal wasn't good.
                                        Didn't realise it at the time.
                                        The printer is a UP2+ which is a reasonable quality and should do better.
                                        Some gears I have here are far better so lather this week [ need a new filament holder as they have changed reel size ] I'll print another 127 off on 32DP using the finest settings.
                                        I may well have chosen a lower resolution by default.
                                        #285295
                                          Haven't bothered to check , (only just thought of it) if the central boss is the right diameter for this, but , a thought.
                                          Could you not produce the same effect by using the existing 80T gears and making two new 16T gears.
                                          If this is feasible, there would be no problems with space, (as long as the banjo will allow 16T gears to be meshed correctly), and the 25:1 reduction would give the finer feed of 0.06mm / rev (0.00236"/rev)with a 1.5mm pitch Leadscrew.
                                          This would provide 0.0025" / rev with a 16 tpi Leadscrew
                                          #285335
                                            The 16-tooth gear will be less than 14mm diameter at the base of the tooth-spaces, which is cutting things a bit fine with a 12mm bore and definitely not enough room for the key.
                                            I think this is the main reason why the supplied 20-T gears are steel, not nylon, although they use small nylon gears on the tumbler reverse..
                                            #285433
                                              Quite right Neil! You've beaten me to it
                                              Have just measured my gears and done some calcs. A 16T gear would have only 0.84mm wall thickness, over the 12mm bore, and the key way, for the 3mm key,will break through into the teeth. Said that I hadn't checked!
                                              Must remember to engage brain before opening mouth!
                                              On an 18T gear the wall would be 1.84mm, but 1.5mm of keyway would leave only 0.24mm (less than ten thou in post Brexit units) under some of the teeth.
                                              So 20T looks to be the minimum useable even number.
                                              The 20T with my machine are "plastic"
                                              So off to do the calcs for cutting a 100T, to see if that would fit inside the cover, and then possibly to find some 8mm thick material, (most likely to be Aluminium).
                                              Apologies if I misled anyone.
                                              #285528
                                              Ian S C
                                                @iansc
                                                For the smaller gears would it be possible to use a stepped spindle through it, say 8 mm diameter, I'm not too sure where the gear fits in the chain. The sizes seem minimal even for a metal gear.
                                                Ian S C
                                                #302154
                                                Dunc
                                                  @dunc
                                                  I am trying to find a printer (company) and provide the necessary info for them. Aside from the STL file what other info should I be prepared to provide? Material?
                                                  Thank you
                                                  #302156
                                                    Posted by Dunc on 12/06/2017 03:07:55:
                                                    Thank you
                                                    Shapeways would seem to be the obvious place to start.
                                                    I've never used them, but have browse the site before, and it all looks very 'professinal'.
                                                    Have a look at this page first: **LINK**
                                                    https://www.shapeways.com/search?q=lathe+gears&type=product
                                                    Then **LINK**
                                                    Create
                                                      Thank you
                                                      Just choose a material. PLA should be fine, I found a site that had done practical tests and found that (despite the bulk properties of various materials) when printed ordinary PLA was strongest of all – except for high-end carbon fibre. Obviously a gear is only practical to print with layers horizontal.
                                                      Ask for decent shell thickness (at least 1.2mm, you could go more) and number of top and bottom layers (I suggest at least 4), and a fill of at least 25%.
