Belt grinder
Belt grinder
Home Forums General Questions Belt grinder
  • #392730
    Michael Malleson
      @michaelmalleson22793
      The contact wheel on my belt grinder has perished and is disintegrating. Can anyone recommend a firm who can supply me with a new one or renew the contact surface ? Internet searching has not come up with anything useful.
      Waiting in hope !! Mike Malleson.
      #26407
      Michael Malleson
        Replacement
        #392741
        Bob Astill
          @bobastill76884
          there is many of these in all shapes and sizes on Fleabay
          Bob
          #392742
          Grindstone Cowboy
            @grindstonecowboy
            Here's one **LINK**
            Bob beat me to it!
            Edited By Rob Rimmer on 24/01/2019 10:24:16
            And not sure where in the world you are, but in Wisconsin there's https://www.contactrubber.com/recover-services/
            Edited By Rob Rimmer on 24/01/2019 10:29:08
            #392745
            John Paton 1
              @johnpaton1
              Hi Mike – not a direct aswer to your question as I do not know of a firm who does these, however if you search in Ebay under Revox Pinch Wheel you will find a couple of firms who remanufacture tape recorder pinch wheels using similar albeit much more precise components. They might be able to help or advise.
              Alternatively it may be possible to obtain a suitable custom made sleeve from Nufox Rubber Ltd Unit 1 Bentleyy Av, Manchster M242GP. Tel 0161 6558800 they made some custom radiator hoses (hand made!) for me which were very reasonably priced and they were extremely helpful.
              Just this week I successfully re-sleeved the rubber drive wheel on my Black and Decker (spit!) powerfile onto its aluminium drive wheel. I took a rubber bush from my 'bits box', bored a socket in the end of a bit of scrap bar to take the o/d of this bush then bored the i/d of the bush to the required size. I then glued and slipped the resulting rubber sleeve onto the drive wheel and used coarse sand paper to work it down to the correct diameter and level surface.It all went well. I am unsure whether you would want Nufox to reinforce the sleeve – maybe a light reinforcement near to the hub to prevent excessive stretch and another layer part way through the depth of the sleeve.
              Trick with machining the rubber seems to be keep it cold, really sharp tool with good top rake and high speed. Others may have better informed advice on this.
              Good luck
              peak4
                @peak4
                No idea of the price, but how about this sort of castor as an alternative?
                Also, I'm sure there used to be places round that re-tyred solid wheels for forklifts.
                A slightly different application, I appreciate, but I've had success with re-treading bandsaw wheels using the granular rubber/cork sheet used for gaskets.
                Bill
                Edited By peak4 on 24/01/2019 11:12:02
