what solvent cleaner to use?
Home Forums General Questions what solvent cleaner to use?
Viewing 25 posts - 1 through 25 (of 35 total)
  • #389698
    simon Hewitt 1
      @simonhewitt1
      I am nearly out of the solvent given to me by a Southern Electric engineer some time go called Kem-Safe. I am not sure how safe it really is! What solvents do you use and recommend? For general workshop use, cleaning marker blue, cutting oil, grease, general use?
      Simon.
      #26383
      simon Hewitt 1
        @simonhewitt1
        #389699
        Chris Evans 6
          @chrisevans6
          I tend to use cellulose "Gun Wash" thinners bought in 5 litre tins it is cheap and effective. For quick degreasing a can of brake cleaner is useful.
          #389701
            White spirit for everything. if something is resistant to that brake cleaner is more powerful. I do have meths but it is fairly useless. Ethyl acetate dope thinner is also good on some things but rather expensive.
            #389702
            Former Member
              @formermember32069
              #389706
              Chris Trice
                @christrice43267
                Acetone is a powerful solvent that is one of the best for cleaning metal BUT it also dissolves most paints, virtually all except stoved enamels. In addition to ones mentioned above, cigarette lighter fluid is a good cleaner that won't dissolve paint or delicate surfaces.
                #389707
                Chris Trice
                  @christrice43267
                  BTW cellulose thinners also works but should be considered the same as acetone being derived from the same chemistry.
                  #389710
                  ChrisB
                    @chrisb35596
                    White spirit, isopropyl alcohol, acetone, MEK
                    All have their uses and I use all, but prefer white spirit or alcohol. Acetone and MEK tend to ruin any plastic or rubber they come in contact with so I only use them on metals which I need to be super clean.
                    #389716
                    DrDave
                      @drdave
                      In addition to some of the above solvents, I also use good old Gunk for stubborn dirt. It shifts oily dirt, but not the paint, and rinses off with water.
                      #389718
                      Pete Rimmer
                        @peterimmer30576
                        Brake cleaner. I get a box of four 5L cans every 6 months or so. Costs less than 40 quid which sounds like a lot but a £2 a litre is a lot less than buying aerosol cans. You have to use a pressure pot sprayer though, the trigger guns don't like it one bit.
                        #389730
                        David George 1
                          @davidgeorge1
                          Simon I use TF90 fast drying cleaning solvent it works great and costs about £5.00 a tin from many suppliers.
                          David
                          #389739
                          Martin Hamilton 1
                            @martinhamilton1
                            I have used many of the methods mentioned above over the years, i now use disc brake cleaner.
                            #389740
                            Speedy Builder5
                              @speedybuilder5
                              Good old days of trichloroethane – cleaned everything, lungs, kidneys – well almost everything. That was followed by Genklene – which was followed by …….TF 90.
                              BobH
                              #389760
                              Robert Hurst 1
                                @roberthurst1
                                KEM-SAFE L.F is marketed by Kemserv but I'm not sure if it's the same stuff;
                                http://www.kemserv.com/solvent-based-cleaning-products-northumberland.php
                                We used PF cleaner when I was working for Balfour Beatty which is brilliant stuff;
                                https://www.socomore.com/shop/surface-preparation/surface-cleaning/pf-solvent/
                                These days i tend to use BCE (Brake Clutch Electrical) cleaner available in 5l cans or aerosol.
                                Cheers, Rob.
                                #389761
                                Nick Wheeler
                                  @nickwheeler
                                  Posted by Chris Evans 6 on 06/01/2019 17:47:10:
                                  That's exactly how I do it.
                                  Small parts off the lathe get a squirt of brake cleaner from an aerosol; dirty parts get scrubbed with a brush from Poundland in a cheap washing up bowl. Thinners is an aggressive solvent(who knew?) so it doesn't take much. Do it outside! Really filthy parts should have the worst of the grot scraped off first.
                                  #389763
                                  John Reese
                                    @johnreese12848
                                    I use mineral spirits for general cleaning. I assume it is the same as your white spirits. Actually the proper name in the US is varnish makers and painters naptha. Where I need super cleanliness like on parts to be held with Loctite I use Acrtone. Where I wan to clean large surfaces of dirt and oil film I use Dawn dishwashing detergent and hot water.
                                    #389765
                                    Mike Poole
                                      @mikepoole82104
                                      YPosted by Speedy Builder5 on 06/01/2019 19:56:21:
                                      BobH
                                      +1 was trico that bad if you didn’t smoke? A lung full of phosgene was likely to be bad news but as a non smoker and with plenty of ventilation you would be ok ?
                                      #389783
                                      Speedy Builder5
                                        @speedybuilder5
                                        For cleaning filthy car bits (30 or more years of muck) – soak in diesel fuel for a week, then power wash, then TF90. I have tried those water soluble de greasers which work for light stuff, but diesel fuel soaks in better.
                                        BobH
                                        #389812
                                          Posted by Mike Poole on 06/01/2019 23:21:15:
                                          BobH
                                          Tricky to say because so much depends on who you are, the concentration, and how long you're exposed to it.
                                          There are two related chemicals called 'Trike', both were thought safe at first and later found to be causing problems. One is more dangerous than the other, but both were eventually restricted.
                                          Phosgene is a serious risk to smokers, but in ordinary use the chemicals cause dizzyness, drunkeness and poor judgement resulting in accidents. Many other issues build up over time – including heart problems and brain damage. There have been many fatalities due to misuse by solvent sniffers, and to maintenance men caught in tanks. As waste both chemicals are linked to cancer and damage to the Ozone layer.
                                          Very often it's possible to occasionally use dangerous chemicals in small quantities without any consequences. You and I using Trike as a degreaser once in a Blue Moon at home is unlikely do any any detectable damage. But that doesn't mean it's safe! The risks of dangerous chemicals like Trike rise exponentially when millions of people are using them, perhaps in industrial quantities, with a few in charge who abuse environmentalists to justify dumping waste at minimum cost to themselves.
                                          No man is an island. I dislike the idea of Australians getting Skin Cancer because Europeans, Americans and the Chinese are careless with solvents.
                                          mechman48
                                            @mechman48
                                            Remember using Trico for degreasing overalls when finished a mill change when I was apprentice… did the job superbly but the stitching didn't last long hence seams coming apart. the stores then organised a cleaning system with an outside provider, for a small fee, which resolved the dissolving seams issue… Ahhh the weird things we did as apprentices. These days I use Brake disc cleaner, white spirits, industrial degreaser etc.
                                            George.
                                            #389824
                                            Samsaranda
                                              @samsaranda
                                              I tend to be very wary of solvents nowadays, during my 22 years in the Air Force we used many different solvents ranging from Carbon Tetrachloride to modern solvents such as Trichloroethane and Trichlorethylene. Research has proved that many of these compounds can be absorbed through the skin and cause damage to the nervous system as well as being carcinogenic. I now wear gloves where ever possible to give some degree of protection and use any solvents outdoors to lessen the risk of inhaling.I do suffer from a degree of paralysis on one side and can only speculate what the real cause of this is. I would urge that you treat solvents with respect they have many hidden dangers.
                                              Dave W
                                              #389826
                                              martin perman 1
                                                @martinperman1
                                                Wouldn't touch trichloroethane with a barge pole, where I did my apprenticeship we had a contractor suffocate in an empty 6 x 6 foot open tank, he wasnt wearing breathing apparatus, in fact I didnt think it was still available.
                                                Petrol or white spirit is what I use.
                                                Martin P
                                                #389827
                                                Philip Rowe
                                                  @philiprowe13116
                                                  Back in the 70s the company that I was working for used carbon tetrachloride for most things but this was eventually replaced with something called Inhibisol. I've always assumed that this was a trade name but what it actually was I've no idea, apart from being an excellent cleaner/degreaser. Has anyone here come across this at all?
                                                  Phil
                                                  #389829
                                                  Chris Trice
                                                    @christrice43267
                                                    Carbon Tetrachloride was done away with on the grounds that it had the nasty side effect of killing people who were exposed to it for too long. IIRC it acted like a nerve agent.
                                                    #389847
                                                    Samsaranda
                                                      @samsaranda
                                                      Inhibisol (TF90) was formulated to replace Trichloroethane, not sure what chemical is.
                                                      Dave W
