There has to be some "gap" – albeit only a very small one.
I am lucky enough to have copies of Kozo Hiraoka's Shay/Climax/Heisler books and since reading them, I've used his recommendations on making good silver soldered joints and fabrications. He goes into the requirements for a good joint in great detail but it can be summarised under the following headings:
1) Use a suitable silver solder and flux
2) Select an appropriate heat source (i.e. torch)
3) Clean the joint surface(s) well
4) Provide appropriate clearance (by machining, by punching or by filing)
5) Fit the parts together securely (but do NOT use clamps!)
6) Silver solder only a few joints at a time (and clean everything between 'solders' )
7) Always flux before assembly
8) Set up an 'assembly' – such that gravity will assist the capillary action (rather than resist it)
9) Provide the part(s) with support where necessary
10) Apply heat from the back wherever possible
11) Apply the heat to the heavier part
12) Help the flow of solder with a 'scratch' rod
This is detailed in Kozo's 'Shay' book but referenced in the others too – but is the best all round description of how to make small soldered fabrications that I think I've seen.
As mentioned, he always makes a slight "gap" between the parts to be silver soldered. I've found his idea of using a centre punch to make a few 'dimples' on one part ( very small 'stand-offs' ) – to hold the two surfaces slightly apart (thereby enabling capillary action) very useful.
BTW – The Kozo books are still available from Village Press in the US (not that cheap I'm afraid given $/£ exchange rates but still much less than some eBay/Amazon sources would suggest). They are beautifully written and illustrated and contain many novel and useful ideas and techniques for any ME. They would certainly be on a short list of my favourite modelling/engineering books.
IanT
Edited By IanT on 12/04/2018 13:27:56
