I would be hesitant about using too much heat … The zinc content is likely to boil-off before you do much good.
It presumably bent cold, so will probably bend back cold.
I would secure a couple of flats to it and use them as levers to manipulate it back to shape.
… Clamp a suitable wooden 'stake' in the vice, and work freehand.
