Cross slide tool
Cross slide tool
Home Forums Workshop Tools and Tooling Cross slide tool
  • #388913
    Adrian Harrison
      @adrianharrison27934
      this is another tool that came with my lathe that looks like it was made to bolt to the cross slide.. would this be a radius cutter?
      #19187
      Adrian Harrison
        #388922
        John Haine
          @johnhaine32865
          A bit flimsy for a cutter…maybe a lever to help with metal spinning?
          #388979
          peak4
            @peak4
            At a wild guess; is the handle on it at about the same height as the feed screw on the top slide?
            If so, how about removing the feed screw, coupling the top slide to this lever and use the whole arrangement as a slotter.?
            As per the first photo on this thread.
            Bill
            #389001
            Adrian Harrison
              the handle is a about the same hight as the one in the picture..
              thats interesting and I'm sure i could make it work like that
              #389018
              Paul Lousick
                @paullousick59116
                Mounting bracket for a dial indicator ?
