Slipping drivebelt
Slipping drivebelt
Home Forums Workshop Tools and Tooling Slipping drivebelt
  • #388084
    Gary Wooding
      @garywooding25363
      I've been bequeathed a Naerok bandsaw, which appears to be identical to the Clarke cbs355. The black rubber? drive-belt has a 1/4" circular cross-section and a length of 23" approx. It looks undamaged but slips under very light load.
      What's the best cure please?
      #19180
      Gary Wooding
        @garywooding25363
        #388091
          Hi Gary,
          Looks like they might use any one of three different lengths of 7mm diameter belt. Might yours need a smaller belt than the one currently fitted?
          Gary Wooding
            @garywooding25363
            Thanks NDIY, but £30 a pop is somewhat extravagant.
            #388207
              Gary,
              If that is the case, you have a few options.
              1) shorten your belt – glued or ‘welded together’?
              2) Change one or the other of the pulleys, depending on whether you would prefer a faster or slower cut.
              3) Wrap some good tape around one of the pulleys to ‘fill it out a bit’ and hope it wears well (probably only a temporary measure?)
              4) Find a cheaper belt supplier.
              5) Change to a narow section V belt system of some type (V, multi V…).
              The single review on the Machinemart site amused me. The machine (no longer available) was constructed so flimsily that it broke, but the reviewer still gave it full marks! An insider review, methinks!
              #388211
              I.M. OUTAHERE
                @i-m-outahere
                Check that there is no oil or the like on the pulleys .
                #388215
                Paul Lousick
                  @paullousick59116
                  Car accessory stores sell spray cans of belt grip solution that stops fan belts slipping. Clean belt and dive it a spray.
                  Edited By Paul Lousick on 30/12/2018 08:54:26
                  #388251
                    Posted by Gary Wooding on 30/12/2018 07:53:19:
                    As l have mentioned before; the Chinese equivalent seems to be of comparable quality to "Polycord" and is much cheaper. [caveat: I have only used the small diameters of the Chinese product]
                    Ref. my post on 03/12/201
                     https://www.model-engineer.co.uk/forums/postings.asp?th=139082&p=1
                    Edited By Michael Gilligan on 30/12/2018 11:39:41
                    #388272
                    BC Prof
                      @bcprof
                      Looking at my 13yr old Clarke version the motor is foot mounted . The slots in the feet would be more than sufficient to allow both taking up the slack needed to stop the existing belt slipping or to accommodate a new belt . I purchased a spare from Machine Mart some 5 yrs a go . I can't remember the price but it certainly was not £30
                      Brian C
                      #388297
                        Working on the assumption that the belt is not bottoming out in the pulleys If it is, you need a larger section belt.
                        If you choose to shorten the belt by cutting and rejoining, Cyanoacrylate ("Superglue&quot is the stuff to use. The cured joint will ,be stronger than the parent material. Cut square across the belt to remove the amount that you feel is necessary, breathe on the ends, apply the cyanoacrylate and hold the ends together for about 30 seconds. You will have a very few seconds to ensure that the alignment is correct. Once the adhesive cures fully, about 30 minutes, you should be ready to go!
                        #388298
                          Howard,
                          I think round belts should drive on the full half-circumference? Not like V belts?
                          Edited By not done it yet on 30/12/2018 15:48:39
                          #388319
                          Dalboy
                            @dalboy
                            I have this machine as well that I was given but there was no belt tensioner on it so I constructed one with a spring to aid keeping the belt tight enough to run and not slip. I use it as a second bandsaw for smaller items
