3″ precision vice
3″ precision vice
Home Forums Workshop Tools and Tooling 3″ precision vice
  • #334671
    sean logie
      @seanlogie69385
      Just ordered one of these so here's hoping I get a good un wink.Anyone else use this type of vice .
      Sean
      sean logie
        @seanlogie69385
        #334679
        John Haine
          @johnhaine32865
          It might help if you were more specific as to type and from where you ordered it?
          #334684
          sean logie
            @seanlogie69385
            #334687
              Mine is only 70mm and it came from our reliable supplier Arceurotrade.
              Perhaps a little more expensive (actually I doubt it) but no risk of getting a wrong un.
              Works well enough.
              Edited By not done it yet on 31/12/2017 22:50:07
              #334689
              Emgee
                @emgee
                Hi Sean
                Looks like a compact unit and look forward to your findings when set up and used.
                Emgee
                #334690
                ChrisB
                  @chrisb35596
                  Whilst on the subject of milling vices, I'm after one for a WM18 mill but cant make up my mind. From most reviews on here it would seem the preferred ones are the DH-1, the Arc versatile, and the precision tool vice… I'm more inclined towards the versatile vice 80mm as it has the largest jaw opening compared to similar jaw sized vices. Not sure if its the right size for my mill tho.
                  Sorry for the thread hijack Sean embarrassed
                  #334696
                  duncan webster 1
                    @duncanwebster1
                    The arc euro looks more useful as it has slots in the side to clamp it to the table. However, how do you move the jaw on either, I cant see any clamp screw. Or does the angled one somehow traverse the moving jaw.
                    #334697
                    John Hinkley
                      @johnhinkley26699
                      I, too, bought one from Arc Euro Trade, preferring the slots to anchor it to the table of the Perfecto shaper that I acquired recently. Works well and is ideally sized for the purpose.
                      New vice fitted
                      #334700
                      Gray62
                        @gray62
                        Posted by ChrisB on 31/12/2017 22:49:43:
                        I've owned a DH-1 for several years and for the majority of milling jobs, this is my goto vice, very versatile, has a bigger capacity than any other vice in the same footprint. Additional Jaws are well worth purchasing
                        #334707
                        sean logie
                          @seanlogie69385
                          Posted by duncan webster on 01/01/2018 00:01:19:
                          This will suit my needs , for it's compactness it' still has 4" jaw opening . There are slots underneath that a hardened Tee pin if you like sits in then you use the allen key to take up the slack by pulling down and towards the fixed jaw .
                          Sean
                          #334711
                            The 90mm Type 2 from Arc is no bigger physically from the 80mm versatile but it will open up to 120mm ( 76mm versatile) and has deeper jaws. The only thing you don't get is the abilty to hold large items for gentle work that the extra jaw positions on the versatile allow.
                            You can also see the hole for the key to tighten the precision ones.
                            J
                            PS The e-bay seller Harryuk is Harry from Amadeal.
                            Edited By JasonB on 01/01/2018 07:41:34
                            #334720
                            sean logie
                              @seanlogie69385
                              I looked at the 76mm versatile ,the different clamping down positions was what I need also the extra jaw opening . I looked at loads of vices and it all became rather confusing in the end . Looked at a few youtube videos …..as you do wink 2. Saw this one on the bay ,the price was right for me and the size plus it'll be more than accurate enough for the stuff I do ,if not it'll be going back wink 2. The Centec vice I have is far from accurate,the fixed jaw has a slight curve accross the face and it will now be demoted to the drill press .
                              Happy New Year to everyone .
                              Sean
                              #334727
                              ChrisB
                                @chrisb35596
                                Posted by JasonB on 01/01/2018 07:15:00:
                                Alright, I thought the versatile could handle 205mm work, looking closer to the listing it says light work only in that config – as you say. Is the table size on your mill similar to a WM18 Jason? that is will a 90mm type 2 fit or it's too large?
                                #334746
                                  “the fixed jaw has a slight curve accross the face”
                                  Isn’t that what a milling machine is good at – milling things flat?
                                  #334757
                                  Neil Lickfold
                                    @neillickfold44316
                                    For my cnc router , I brought a pair of Toolmakers vices, similar to what is listed , but from a local tool company. They are within 0.01mm everywhere to being the same. I mounted them onto a sub plate that has dowels to located the vice to. 3 pins , 1 is an end stop, and the other 2 are a side stop. These are spaced so that I can have the vices 25mm apart to a max of 200 mm between the 2 vices. The dowels are a neat slide fit for the side pins, so can be removed if required. I'm very happy with them so far and it's been 2 years now. The new vices all seem to have the short retaining pin that can be loosened off and then slide to the next hole point. The older ones used to have a through dowel that needed changing and that really was a pain at times. I used M8 capscrews for the end clamps, so the 6mm allen key does all the clamps and the vice jaw tightening. Mine also has M8 threaded holes for the side stops etc as well.
                                      Posted by ChrisB on 01/01/2018 08:48:35:
                                      That is the table of the SX2.7 which is 140 x 590. Yes 90mm type 2 against the 80mm versatile both suit that size table, you may be able to go larger on your WM18
                                      #334835
                                      Jon
                                        @jon
                                        Having had to replace another rebranded Versatile 5" from JLS that broke the back out i replaced with a 120 Type 2 and regretted every second with it.
                                        In hind sight its quite a good vice but its the constant annoyance of having to use an allen key with limited travel. Even worse back out 1 rev too much to clear the underside indents and nut drops off. You will send more time faffing about than using.
                                        Personally i would risk the Versatile again and put two rows of off the shelf cheap bearings in about £2, wish i had.
                                        #334838
                                        Ian P
                                          @ianp
                                          Posted by Jon on 01/01/2018 21:59:47:
                                          Must say that my experience with the Allen key type vice is the same. I bought one of the smaller ones because I thought it would be good for holding small components but I hardly ever use it. Two reasons, one is the step in the jaws which never seems to suit the part I am gripping, and secondly there is no method to secure the vice to the table so it has to be held in my main chuck, which sort of defeats the object.
                                          Ian P
                                          #334843
                                          Neil Lickfold
                                            @neillickfold44316
                                            Ian, That is why I made a sub plate to hold the vices with. The new ones have a sping and are very user friendly. I have never had the bottom nut come off yet at all.
                                            Neil Lickfold
                                              @neillickfold44316
                                              I have since added some more hold down clamp holes and more dowel holes. The new holes were done in position after the plate was put in place.
                                              #334933
                                              Ian P
                                                @ianp
                                                This is the vice I have. I bought it about 5 years ago from a reputable supplier (Chronos I think) and should have returned it immediately. I recall that the main picture on the web page did not show this smallest sized one but I expected it to have the same features as the rest of the range. I dont think the larger ones had the stepped jaws but on this vice they are about a third of the jaw height.
                                                This vice might be precision ground but not to any precise dimensions, nearly every feature is unequal. the grooves on ether side are different heights by 0.1mm, the moving jaw is flush to the body on one side and 0.4mm clear on the other. The slot is offset by over 1mm so I ended up making a new trunnion nut so that the screw had a straight pull.
                                                As regards fixing it to the milling table, there are two diagonal M4 tapped holes on the underside but to me it does not seem good engineering to have to mount the vice on a plate. The M4 tapped holes in the side faces are even less sensible and one of the four needs a tap putting through it (it chews up HT screws) but being hardened I dont want to waste a tap.. Neil's vice does at least have notches at both ends so is straightforward to clamp down.
                                                My main vice is a 68mm 'Precision' vice which is I think intended for metrology purposes rather than milling duty. Whilst it has a certificate of accuracy (parallelism/squareness/hardness etc) typically to about 0.005mm and better, the screw is quite coarse pitch and a very rattly fit, quite out of keeping with the rest of it.
                                                Ian P
