Zyto Lathe – Info and Parts wanted.
Home Forums Manual machine tools Zyto Lathe – Info and Parts wanted.
  • #387201
    Paul Kennedy
      @paulkennedy14200
      Hey Guys, Im looking for any information, litrature or parts for a 1950 ' s Tyzack and Son ZYTO Lathe. Specifically missing 45 and 50 tooth change gears, Change Gear guard, Pulley guard, Countershaft with flat pulley's, suitable flat belt, motor 1/2 hp — 3/4 hp should do. Single Phase. 7/8" bore 9t.p.i faceplate, 4 or 6 ", 3 jaw chuck. Preferable slim version with afore mentioned bore and thread or backplate with as mentioned.. And offcousre photos of your Zyto. List is ongoing but if you can help then please contact me. or replay. THanks
      Paul Kennedy
        @paulkennedy14200
        #387210
        Nicholas Farr
          @nicholasfarr14254
          Hi Paul, have you at this **LINK** for some photos and info?
          Regards Nick.
          #387226
          Oldiron
            @oldiron
            I might have a flat belt countershaft from a Zyto in storage somewhere but will not be able to get to it until after new year. Message me your email and I will find it asap and send you the details. I also have some odd gears I believe came from the same machine but it will take some digging to find them.
            regards
            #387231
            Brian Wood
              @brianwood45127
              Hello Paul,
              I'm pretty sure the standard Myford change gears will suit, I don't know about the bore diameter or linking detail but suspect the Zyto equipment was mostly a crib from the Myford ML 2-4 series. For reference the Myford gears are 20 DP with a pressure angle of 14.5 degrees [as they mostly were in those days] with bore diameter of 0.625 inches. Linking was by a small diameter pin in the hub, today there is a 1/8 inch wide keyway cut in the bore, but plenty of room for a pin nearby.
              From about April next year I will have either a Crompton or a good Gryphon 1/2 HP single phase motor 1425 rpm motor surplus for purchase, send me a PM if you are interested.
              Edited By Brian Wood on 23/12/2018 10:08:53
              #387267
              Brian Wood
                @brianwood45127
                Hello again Paul,
                I have sent you a PM. Click on your Inbox on the green header to this page and follow the instructions.
                #387465
                Paul Kennedy
                  @paulkennedy14200
                  Sorry Brian, Don't fancy modifying an origional item. Call it my OCD but i prefer to keep it standard. Im planing a cheep and nasty chineese faceplate and modify it if i cant find an origional.
                  #393215
                  Paul Kennedy
                    @paulkennedy14200
                    Posted by Oldiron on 23/12/2018 09:54:50:
                    regards
                    Any progress yet ?
