Or could they be genuine, sort of?
Intense research into battery technology for at least 30 years, first for laptops and mobile telephones, now because of the increasingly urgent need to replace internal combustion engines in cars and to store erratic green electricity.
Considerable progress has been made! The batteries in USB rechargers are the same technology as those used to power electric model aircraft – high capacity and light weight rechargeables. Battery powered flight? Not in my young day!
900000mAh isn't equivalent to 900A for an hour; I doubt the batteries chemistry is up to that, or it's terminals! The capacity still seems unlikely to me, but is it unrealistic compared with the energy density of petrol, about 46MJ per kilo?
Anyone else up to checking the maths? What's 900000mAh at 5V from a 280g battery compared with 46MJ from 1kg of petrol?
As these things are only £10, I might take a punt and measure one! As their main purpose is recharging mobile phones, I guess the max amps output will be in the USB as power-supply range, no good for starting car engines! I suspect they won't last long either – the warranty is only 3 months.
Almost everything I learned about battery capacity at school is out-of-date. Super-capacitors were ruled impossible. NiFe cells, gone. Zinc Chloride, almost gone. Lead Acid – much improved. Since leaving school, Daniels, Weston and most other special types, gone. Mercury, gone. NiCAD almost gone. Today, Lithium rises; it's a battery Jim, but not as I know it…
