Like Andrew i have a Hamier 3D Taster for really accurate alignment but for normal duties I use the Huffam version of the Starrett wiggler set in Brian's picture. Have both metric and imperial versions which avoids conversion errors or, more correctly, forgetting to switch the DRO system back after using an imperial wiggler on a metric job or vicky versa.
The Huffam set only has ball and cylinder probes so in a sense its less versatile than the Starrett set. But the pivot bearing uses a spring loaded nylon pusher to apply constant, light, pre-load making it more sensitive than the more common Starrett and no name knock off types. Getting down towards ± a teeth of a thou or so if you are careful the machine adequately tight and the surface finish on the target decent. Since getting the Huffams the Hamier barely gets used. It needs to be pretty picky job for the Hamiers better performance to show.
Picked up a no-name version of the Starrett set with my first mill years ago. Its OK but the ball in a collet pivot isn't really reliable below ± a thou or two. Fiddling about with the collet adjustment can help matters but life is too short. I keep it for the needle point. Short of proper spindle mount optical or camera system its the bees thingies for picking up intersecting lines and centre pop marks. Pivot stiffness is an advantage there.
Clive.
