What size DRO on SPG 2217 – BF20 Mill
Home Forums General Questions What size DRO on SPG 2217 – BF20 Mill
  • #189659
    Neil Bradshaw
      @neilbradshaw24930
      Hi
      Can anybody help me solve a bit of a mystery.
      I want to fit DROs to my X and Y axis on my SPG 2217 mill
      From what I have found out in the manual the maximum X axis is 565 mm on the Y axis it is 220mm.
      From what I have worked out I need a 600mm linear scale for the X axis
      and a 250mm for the Y axis./
      Is this correct or has anybody else got any suggestions or advice
      Thanks
      http://www.southshields-weather.co.uk
      Neil Bradshaw
        @neilbradshaw24930
        #189666
        Stuart Bridger
          @stuartbridger82290
          Neil,
          Machine DRO have a measuring guide on their website.
          Stuart
          #189673
          Enough!
            @enough
            You need the measurement length (not the overall length) of the scale to be at least equal to the maximum travel of the table in that axis. In practice, if they are exactly equal, mounting the scale will be a bit finicky since you'll have to exactly match the scale/table travel at each end.
            In practice you need a bit more scale travel than table travel …. the more the better up to a point but that will be limited by considerations of how you will mount the scale (remembering that the overall scale length may be quite a bit longer than its measurement length). The other part of the trade off is, of course, cost. Longer scales cost more. Scales also usually come in discrete length increments.
            The lengths you have suggested (assuming they are scale measurement lengths and not overall lengths) sound about right. However, don't take the manual's word for the table travel – measure it yourself.
            #189674
              That sounds a bit tight to me. on the X axis you would only have 35mm and just 30mm on the Y axis to fit the read head and two fixing points without any allowance for the scale not being perfectly placed to use all the available travel.
              For my chinese scales the read head is about 40mm long, and allow a good 20-30mm for each fixing point, so up to 100mm extra scale length needed.
              Enough!
                @enough
                Posted by Neil Wyatt on 12/05/2015 21:50:29:
                You can often accommodate that by building a "jog" into the bracket that attaches the slider …. effectively centralising the scale. But I agree, if those lengths have to include the end fixing points, they are too small. That's not clear to me in the OP.
                #189689
                Paul Lousick
                  @paullousick59116
                  The working length of the scales should be longer than the maximum travel of the mill. If the scales bottom out they could be damaged.
                  Paul.
                  #192316
                  Redpiperbob
                    @redpiperbob16487
                    Hi Neil
                    I have only just seen this thread.
                    I have just DRO'd my SPG 2217 III
                    These are the sizes I fitted to mine
                    100-060-10200 2 Axis Digital Display Unit – USB   £69.05 1 £69.05
                    100-040-10300 Horizontal Digital Readout Bar 200mm/8" Large Display   £22.39 1 £22.39
                    100-040-10600 Horizontal Digital Readout Bar 500mm/20" Large Display   £61.20 1
                    £61.20
                    I got them from Arc Euro Trade ( No link To them I am just a satisfied customer )
                    Bob
                    <edited to stop table going off to the right>
                    Edited By Neil Wyatt on 04/06/2015 20:49:30
                    #192327
                    mechman48
                      @mechman48
                      Hi Neil
                      I have fitted similar dro's to my VM 16 as Bob; but I have the scales that have remote readouts as opposed to having the 2 axis display unit… in the similar lengths… ArcEuro #…. 8" & 24"
                      100-061-00200… 8"
                      100-061-00500… 24"
                      http://www.arceurotrade.co.uk/Catalogue/Measurement/Digital-Readouts-with-Dedicated-Remote-Display
                      So far both have served well for my needs & the cost is reasonable… See my pics in my album… 'DRO' …for fixings.
                      George.
                      Edited By mechman48 on 04/06/2015 10:13:31
