What did you do today (2015)
Home Forums The Tea Room What did you do today (2015)
Viewing 25 posts - 1,526 through 1,550 (of 3,154 total)
  • #193472
    Clive Hartland
      @clivehartland94829
      Regarding welding of shotgun barrels, I bought an American shotgun, 'Savage' comes to mind and the first time out the forend came off in my hand as i fired. Looking at it, the forend fixing lug had been welded onto the underside of the barrel and had failed! it was changed without question and I swopped it for a Simpson S/S of Suhl. a beautiful gun. Then like a fool swopped that for an Ithaca which was rubbish.My present gun is a Beretta O/U and is silver soldered barrels. Very reliable.
      Edited By Clive Hartland on 15/06/2015 07:57:11
      Hopper
        @hopper
        Posted by Neil Wyatt on 15/06/2015 07:19:32:
        > these old 'uns are more good and solid than the new stuf
        Which is why it was rusty and full of holes
        N.
        It would have been OK except some sugar cane farmer left it sitting on the dirt floor of his open-sided tractor shed for about 20 years too long. Not a good look when you get more than 6 feet of rain a year.
        #193496
        JohnF
          @johnf59703
          Graham, it's the joint that you see on your gun that is now often laser welded so it does not show but there is insufficient strength for service so initially the new tubes are soldered or fixed with engineering adhesive into the reworked breech.
            @mike89748
            The only laser welding I have ever seen on European shotguns was used by Beretta to attach the barrel tubes to the chambers and lumps on their side-by-sides. I saw this operation on a visit to the factory about ten years ago. I now understand Beretta have abandoned the process, which suggests there was a weakness. Anyone know more?
            #193560
            Nick_G
              @nick_g
              Yesterday really not today. But sort of engineering based.
              Decided to go for a few hours carp fishing. It's been a few years since I went so purchased some new line and came to wind in onto the spool.
              My reel had gone defunct.! sad
              Investigation revealed this :-
              So had to go and grab a new reel before I ventured forth onto my expedition.
              Nick
              #193561
                What did I do today ?
                … Became extremely irritated by the new, and very persistent, pop-up advert for a trial subscription.
                … I AM AN EXISTING SUBSCRIBER …
                Edited By Michael Gilligan on 15/06/2015 18:15:33
                #193563
                Keith Long
                  @keithlong89920
                  I'd like to add my whole-hearted endorsements to MichaelG's comment above – a large boot applied to the rear end of whoever thought that was a good idea comes to mind!!
                  #193564
                  Ed Duffner
                    @edduffner79357
                    Posted by Nick_G on 15/06/2015 18:10:02:
                    Nick
                    Hi Nick,
                    If you decide make a new gear for your reel, it would be interesting to see how you tackle it. (if you feel like sharing the process).
                    Ed.
                    #193565
                    Boiler Bri
                      @boilerbri
                      I am right behind you Micheal, so annoying.
                      #193566
                        Posted by Ed Duffner on 15/06/2015 18:45:51:
                        That's a good line
                        #193572
                        Ed Duffner
                          @edduffner79357
                          Well spotted Michael laugh , completely unintentional pun.
                          Ed.
                          #193573
                          Lathejack
                            @lathejack
                            image.jpg I've been fiddling with my newly acquired BSA again, changed the oil and thoroughly cleaned out the oil tank as there was a bit of oily sludge in the bottom. Sent a small camera into the engine internals where I could get it and it is as clean as a whistle.
                            So I popped it in the van and took it for an MOT, which it passed. Not bad for an old rattler bought from an Autojumble.
                            #193574
                            frank brown
                              @frankbrown22225
                              I'm hooked. How big was that fish? face 1
                              Frank
                              #193575
                              Lathejack
                                @lathejack
                                Oil pressure.…………………Wonders will never cease, an old BSA with some oil pressure. Running from cold it produced about 25 PSI on a slow chugging idle speed, with just over 40 PSI on a slightly faster idle. With about 3000 RPM it produced around 70 PSI.
                                A 1972 version of this engine I tested a few weeks ago gave 70 PSI at a slow idle speed, these have an uprated cast iron oil pump which is not so easily damaged or worn.Engine sump plate.
                                I also repaired one of the engine sump plate threads and replaced the 1/4 inch cap screws with studs and nuts. The studs have been made long to accommodate a new, thicker alloy sump plate I plan to machine from a billet of aluminium. This is a common area of damage and bodgery. I knew the home workshop would turn out to be useful for something.
                                Edited By Lathejack on 15/06/2015 19:30:46
                                #193582
                                  Hi folks,
                                  If the pop-ups keep appearing and become too irritating, I can ask for them to be taken down. Bear in mind that the cookie that knows you are logged doesn't know if you are a subscriber or not.
                                  I'd rather give it a few days because we all know that a batch of new subscribers is better for all in the long run.
                                  See it as a punishment on those who are inflicting the fish-pun thread on the forum. It just isn't the plaice.
                                  NJH
                                    @njh
                                    Yes it is very annoying – maybe we should offer some inducement for the removal – payment could be made C.O.D maybe?
                                    Norman
                                    #193588
                                    Nicholas Farr
                                      @nicholasfarr14254
                                      Posted by Michael Gilligan on 15/06/2015 18:14:42:
                                      Hi, I have also muttered a few un-mentionable words about it, one phrase ended with the word off.
                                      Regards Nick.
                                      #193592
                                        Can anyone else who wants to comment on the pop-up do it in this thread, may keep all the happy comments in one group that way
                                        #193597
                                        speelwerk
                                          @speelwerk
                                          Posted by Neil Wyatt on 15/06/2015 19:58:15:
                                          Hi folks,
                                          It also does not know if you are a UK citizen or not, so it is double annoying for those living outside the beautiful UK.
                                          Niko.
                                          Edited By speelwerk on 15/06/2015 21:01:29
                                          #193599
                                          Nick_G
                                            @nick_g
                                            Hi Nick,
                                            Ed.
                                            I can assure you the price of a new reel these days making a new gear is not worth the trouble. The original looks to have been a casting (see what I did there wink) and had no machine finishing. Looks to be made of 'Chinese cheese metal' The make is by Browning.
                                            If anyone wants it for experimentation purposes or fancies making a new gear for it they are welcome to have it.!
                                            Nick
                                            #193608
                                            Phil Whitley
                                              @philwhitley94135
                                              Lathejack, is that by any chance a BSA Baracuda 250cc with the fiberglass tank? Mate of mine had one in the seventies.
                                              #193611
                                                I've made further comment on the thread Jason links to.
                                                Bear in mind the marketing folk won't see these comments or my emails until tomorrow…
                                                Nick – I saw some lovely reels in Wales a couple of months ago. They knocked the spots off the ones I used to use when I was into beachcasting, rear drag and all the goodies. A multiplier too. And all about half the price I was paying back in the 80s!
                                                capnahab
                                                  @capnahab
                                                  And for tonights quiz,,,,,
                                                  Did some fettling of this mystery item from 1956. img_6195.jpg Very nicely made indeed. The brass spigot even had a screwdriver slot so when reasssembling it can be oriented correctly. A very heavily engineered item but functionally really nice, should give you a clue to the manufacturer. So what is it and what lathe did it come with?.
                                                  #193628
                                                  Lathejack
                                                    @lathejack
                                                    Capnahab
                                                    It looks like a micrometer carraige stop, maybe from a Smart & Brown Toolroom lathe, or Hardinge.
                                                    Edited By Lathejack on 15/06/2015 23:30:18
                                                    #193629
                                                    Bazyle
                                                      @bazyle
                                                      Got the parts for the Cricket Club mower (£15+VAT postage rip-off) only to hear the tractor wheel bearing has gone. Arranged to borrow a hi-lift jack for tomorrow but need a stand and the famous Fergie spanner (allegedly one spanner fits every nut).
                                                      On a better note I got some castings at the last club meeting and hear someone else was after them today – but I got in first he he!
