Hi Andy. Yes you can get a multi function welder. I was looking at them before i bought my present Tig welder. For a good quality one , they are quite expensive. In the end i opted for a top quality Thermal arc / esab HF Tig unit so i could do aluminium as well as other types of metal. I bought this 2nd hand & i think it was something like £900.
It is AC. & DC. which also does stick welding. You could use your 100% argon gas if desired. For most mig welding a 95% Co2 5% argon is the ideal. A lot of folk use 100% Co2. But for a clean shiny weld with less spatter, the 5% argon is the best. If you want to do stainless mig. (METAL INERT GAS) then you need 100% Argon or as it is called Argoshield. Some of the comments are incorrect. You never want Oxygen anywhere near your weld. This introduces oxydization. This can be seen if you try to weld with no gas, you will end up with lots of pin holes in the weld & the metal will have carbonized & the actual weld turns brittle & breaks very easy. This is in the word inert. The whole idea is to shield the arc from oxygen, using an inert gas. Molten metal & oxygen pretty much = Carbon.
I have had a few Mig welders & they are very good for items like car bodywork etc. No good for thick steel as they cannot penetrate like stick does.
At the end of the day what do you need it for. This time i chose to go Tig so that i could do alloy as well as brass. (Not tried yet) Stainless & mild steel. I have no regrets on not getting a MIG/TIG set.
This is where i have to be careful of what i say. Rules etc. Only that the one i have now is an American made machine. It is difficult to assertain where one is made because of european companies badging is not always made in europe. This is my 3rd Tig welder ,but only the 1st with both AC & DC.
The last 2 did not last very long & were made in China, although badged as Stanley. It was only when they went pop & i rang Stanley for backup, only to be told the Stanley name is not british any more. The 2 i had bought for work ended up in the bin. But they were very cheap ebay offerings & did pay for themselves 10 fold before failing.
Also if you have never done Mig, it is very easy to get up to speed. If you are right handed then with your stick welding you would have laid the weld from left to right. With mig you weld from right to left, & the same with Tig.
Look on youtube there are some very good vids showing how it is done. Hope this helps.
Steve.
Edited By Steviegtr on 03/09/2020 23:07:27
