Hi Sean,
The link below is to a manual for the EC03 and EC04 series of Robin engines. It shows a few styles of crankshaft ends. If you have one that is not tapered but is straight diameter with a threaded stud, finding a clutch for it will likely be easier. In any case, it would be wise to check with the nearest Subaru/Robin/Wisconsin small engine dealer and ask them what Robin factory clutches, if any, will fit your engine. You can usually find the local dealer with google (search for "robin engine dealers (your town name)" or a yellow pages phone book (look under "small engine repair/dealers" Be sure to explain your project as a home shop job. You may be surprised at the useful bits and pieces the shop guys will dredge up for projects like yours at low or sometimes no cost for experimenters like yourself.
http://www.subarupower.com/media/manuals/128901556262286250.pdf
Good luck with your project.
Another engine type handy for carts is chainsaws – they all have a centrifugal clutch built in, and depending on model, the chain sprocket may fit small drive chain. I had several carts and bikes powered by scrapped/refurbed McCulloch and Pioneer chainsaw engines when I was younger.
Edited By Jeff Dayman on 03/09/2015 21:01:41
Edited By Jeff Dayman on 03/09/2015 21:01:55
