Yes there is, but whether it's useful depends upon how hard you run the lathe.
In simple terms the torque of an induction motor is proportional to the current. So running at 50Hz with rated current the motor will produce a certain amount of power. Now if we run at 25Hz, without changing the belts, the VFD will ensure that the rated current stays the same. But since the frequency has halved the motor speed will be halved and hence the power at the spindle will also be halved.
Now assume we change the belt position (for convenience assume a 2:1 ratio) and run the motor at 50Hz again. Since the motor is running at 50Hz and rated current it will produce the original amount of power. But since we have a 2:1 reduction in speed via the new belt position the spindle will run at a speed as if driven directly by the motor at 25Hz. But the motor is generating the original amount of power, so if the spindle speed has halved the torque at the spindle has doubled. So belt drives via different pulleys allow speed changes while keeping the power transmitted a constant (minus the small losses in the belt).
So varying the motor speed with the VFD and not changing belts results in varying power at the spindle. Changing belts and keeping the VFD at a single frequency results in constant power at the spindle. That may matter if you want to turn large parts at slow spindle speeds, like a flywheel.
In practice one probably would do both, for smallish parts one would just change the frequency on the VFD. But for larger parts it would be advantageous to change the belts.
I'm well aware that VFDs can allow over-current operation, and hence more torque, but that's not a good idea in the long term due to heating issues in the motor windings.
