Unusual GPO hammer?
Unusual GPO hammer?
Home Forums The Tea Room Unusual GPO hammer?
Viewing 8 posts - 26 through 33 (of 33 total)
  • #431115
    Robert Atkinson 2
      @robertatkinson2
      I inherited a small hammer from my father in law (an American) that looked similar but the back end was straight with a narrow slit in it. It looked like a claw but almot closed. I discovered that it is intended for holding pnel pins or tacks for the first blow. It's magnetised with one side North pole and the othet South so the pin is helad firmly and centered between the two halves. Similar to this
      Robert G8RPI.
      Don Cox
        @doncox80133
        My career progression with PO/BT reads exactly the same as Peter Shaw's, except my attendance span was 1963 to 96 when an indecently financial incentive tempted me to take the money and run at age 50. Indeed my level 2 manager during a significant part of my time there was a gentleman also named Peter Shaw.
        I enjoyed repairing 'phones and call connect (switchboards etc) systems and also maintaining exchanges at various times. For ten years I looked after rural exchanges all on my own, the last selection included two TXE2s (processor controlled reed relay switched "electronic" exchanges) and a couple of UAX 13s (Unit automatic Strowger exchanges, I also had a UAX 14 at one time too), I look back on this period as the high point of my time there.
        The rate book, or "Vocabulary of Engineering Stores" as it was also called, had one major failing in my experience. Items were listed with a "Unit of Issue" which did not always make sense. For instance, for wood screws it was 200, which resulted in one of my inexperienced colleagues receiving 30 boxes of 1" X 6 screws with an accompanying note from the store-man saying that this was all he had in his stock but that the remainder of the 200 boxes ordered would follow as soon as he got them, likewise jumper wire was "per metre" which resulted in a copy of the demand note arriving with a metre length of blue/yellow wire stapled to the top instead of the expected 200M drum. This situation was greatly exacerbated by the closure of local stores counters when the store-man could talk to you, and their replacement with centralised stores accessible only by Fax.
        I enjoyed my time there (with the possible exception of my three years as a manager), the camaraderie was great, the training generally excellent, and it gave us, and still gives us, (my wife was also a GPO telephonist) a good living.
        Don Cox
        #431142
          Posted by Don Cox on 30/09/2019 08:41:28:
          The rate book, or "Vocabulary of Engineering Stores" as it was also called, had one major failing in my experience. Items were listed with a "Unit of Issue" which did not always make sense. For instance, for wood screws it was 200, which resulted in one of my inexperienced colleagues receiving 30 boxes of 1" X 6 screws with an accompanying note from the store-man saying that this was all he had in his stock but that the remainder of the 200 boxes ordered would follow as soon as he got them, likewise jumper wire was "per metre" which resulted in a copy of the demand note arriving with a metre length of blue/yellow wire stapled to the top instead of the expected 200M drum. [ … ]
          Perhaps I am missing something, Don …
          How does an explicit declaration of the “Unit of Issue” qualify as a major failing of the system ?
          … both of your examples read like “Pilot error”
          Don Cox
            @doncox80133
            Michael
            I think the point was that the units of issue were not always sensible and, if you were a rural linesman, out of reasonable reach of a store and at the end of a long day out in the rain, trying to guess what the unit of issue might be (bearing in mind the nearest rate book with its family bible proportions probably resided remotely in your bosses office) mistakes were likely. We were a comms company after all and I think a quick 'phone message from the store-man to check what was really wanted might have fixed it, I think most times they were just having a laugh.
            By contrast a chair bound "engineer" with access to the book and a background of finding his way around it would seldom slip up I guess.
            Worse, there was no apparent way back for over-ordered stores so I remember abundant amounts of wide insulation tape, washing up liquid, red coloured marker cards and many more items being offered around to all and sundry to try and lose them.
            Don Cox
            #431147
              Posted by Don Cox on 30/09/2019 09:37:18:
              Every cloud has a silver lining angel
              bill ellis
                @billellis45274
                GPO Storemen seemed to be a law unto themselves (probably the same with most supply departments), One instance that comes to mind was when going into get an item and being told "no I can't let you have that as it's the last one, and someone else may need it". Not sure if they had a method for evaluating need or could just not be bothered to go and get it. Seems they employed the most cantankerous gits as storemen (apologies to any ex storemen).
                Like others I managed a good few years (36) in GPO/British Telecom/BT, from 74 to 2011, progressing through usual path of TTA, T2A, TO, TOA, AEE, EE, MPG4, PCGU, PCGT, PCGS Then early retirement at 53. They had various naming schemes for different levels over the years, AEE (assistant executive engineer) became a level 1 manager, then a MPG2 (management professional grade). PCGs were personal contract grades, although there was very little personalisation as pay was still within set bandings.
                Speaking to ex colleagues who have recently retired, the company has changed beyond recognition (and not for the better), glad I got out when I did with happy memories of the old engineering days.
                #431154
                Peter G. Shaw
                  @peterg-shaw75338
                  Don,
                  I wasn't your manager! And whilst at one point I worked with another Peter Shaw, he was on EL&P. Unfortunately, I was actually P G Shaw, whilst he was P H Shaw. Guess who got all the 'phone calls!
                  I must admit that I had forgotten that idiosyncrasy of the Rate Book re "Unit of Issue"
                  And yes, like you I took the money and ran. Not surprising really as BT pulled the rug out from under my feet. After declining TXD training in favour of remaining as a TXE4 planner, BT suddenly advanced TXE4 closure, stopped all TXE4 planning and I was out of a job.
                  And also like you, my wife was a telephonist.
                  Bill,
                  My brother, also a GPO/BT technician but younger than me, said exactly the same thing (re change), and couldn't wait to get out. Unfortunately, he was too young for the Early Release programmes, and finished up having to wait until around 60 otherwise he would have lost a lot of his pension.
                  Peter G. Shaw
                  #431247
                  Howard Lewis
                    @howardlewis46836
                    Sounds like the GPO system was based on the military stores system
                    "Capes, Waterproof, Small, Officers for the use of" etc.
                    When Southdown Motor Services computerised the stores records, it was done by an ex military chap, who had spent WW2, or much of it in Egypt, on clerical duties.
                    Anything to do with a gearbox was recorded as Gearbox. Could be "Assembly", "Bolt Securing", Washer Plain" or " Rubber" ( meaning a rubber mounting ) Very logical, but took ages to find the right code to order what you actually wanted, and sometimes you did not! Which was a right pain when the vehicle needed to be back on the road for the rush hour. Eventually, we learned how to defeat the system, to get what we wanted and in the right quantity.. Until then, we had a massive stock of things like "Pins – split" and rarely the size we needed
                    At C A V, in the Diesel lab, we had a store keeper, just like the one mentioned. "You can't have that tool, its the last one and someone else might want it" The coefficient of frustration rapidly approached unity!
                    No wonder we have high blood pressure.
                    Who said "The good old days"?
