I would appreciate any comments on the useability of the Emco Unimat lathe / Mill combination – good bad or indifferent, and pitfalls, best model etc!
Principally the rig will be for clock repair and restoration for spring wound mantle types such as Smiths Westminsters, up to 30 hour & 8day English longcase, plus French Comtoise movements, so the biggest diameters it will probably need to handle, are mainspring barrels and gut/chain driven great wheels which need bushes makiing and fitting.
My predicament!, I'm wanting to rationalise all the gear I carry with me to France and back, (Twice a year,) and as my wife keeps rminding me, I'm not getting any younger, and would like to simplify the job a bit.
I'm currently using a Boley 8mm watchmakers lathe with compound top slide etc for my smaller watch and clock related repairs, and use a larger modelling lathe for the bigger clock stuff,
In addition, I have a Clarke CMD10 for any milling work, of which I've done so little, it's a virtual wasted chunk of money sitting on my bench.
My Boley stays put, but the thought is to get rid of the larger lathe and Clarke mill, and get a combined outfit like the Emco, which would appear to be capable of all I need for bigger stuff with availability of a milling fuction, and crucially, a lot less bulk and weight to heave around, plus less bench clutter.
Gear cutting doesn't need to be considered, I just buy 'one off' clock wheels from a BHI pro' when needed, and any milling work is more likely to be small repair jobs.
So in short, is the Emco worth the money they go for, are spares plentiful, and are they reliable?
Many thanks,
John.
Hmmm, looks like I can edit my post but not the typo on the header, grrrrrrrrrrrr ……………
Edited By RJW on 03/04/2012 14:05:00
