Stuart Twin Victoria (Princess Royal) Mill Engine
Home Forums Work In Progress and completed items Stuart Twin Victoria (Princess Royal) Mill Engine
Viewing 25 posts - 376 through 400 (of 1,267 total)
  • #557823
    Dr_GMJN
      @dr_gmjn
      By the way – I guess I touch on the top of the mandrel with the cutter, from that I can get the offsets from the axis for the valve and foot faces?
        If the mill does have any tram issues then you will get a flatter port face by using a smaller sharp cutter say 6mm dia 4-flute cutter with a 4mm stepover. You could take a pass with the facemill to get under any skin then final cleanup with the endmill.
        #557832
        Ramon Wilson
          @ramonwilson3
          Yes definitely in agreement with Jason on that suggestion – much the better way to achieve a flat surface.
          I use a 6mm dowel in a drill chuck, touching on each side of the mandrel to find the centre and as you say touch the cutter on the top ( I use a .0015 shim in between the cutter and mandrel) and zero that as datum.
          By all means support the casting underneath but you should not need to clamp it if you keep the cuts light. If the packing is not the exact thickness you will distort the angle plate however slight. I use a 6mm caphead in a tee nut as a jack for times like these – works well. Even letting the job find it's own level then bolting the mandrel in place is not ideal – much better to have the mandrel float then support the job
          Looking good yes
          Just found this which will give you the idea
          Edited By Ramon Wilson on 11/08/2021 08:14:41
          #557833
          Dr_GMJN
            @dr_gmjn
            Thanks Jason (ETA Ramon – you responded while I was writing this!) yes I remember the discussions about that last year when I first got the mill. I couldn’t get a good finish with milling, so I think you suggested fly cutting, which worked very well. I’d rather stick with that or the shell mill (which also gave a great finish on the beds). I’ll do the feet with a mill because clearances might make other methods tricky.
            I did spend a considerable amount of time re-tramming the mill earlier this year, and am satisfied it is good. However I’ll re-check it before starting the faces.
            By the way, the valve face cast pad is about 1.5mm undersized to the drawing on width, which will make the block overhang. I guess reducing the width of the block and its cover, and re-spacing the holes and studs is OK? I don’t fancy JB Welding around it, especially since the exhaust port cast pad is in the way.
            Edited By Dr_GMJN on 11/08/2021 08:17:40
            #557837
              Yes I altered the stud pattern and then milled all three parts flush
              #557839
              Dr_GMJN
                @dr_gmjn
                Posted by JasonB on 11/08/2021 08:46:51:
                Ah OK. Did you machine the exhaust port pad off then?
                #557946
                Dr_GMJN
                  @dr_gmjn
                  I set up the mandrel as suggested, with snug supports under the overhanging foot plates, but not clamped. I did rebate the rear of the mating boss a bit after all:
                  So after aligning the angle plate, the mandrel ended up about 0.0005” out of level and about 0.001” out of x-parallel. It’s difficult to know what’s acceptable, but I didn’t think I could realistically get much better, so went ahead and machined the valve face:
                  After some minor flatting on the surface plate it seems to be pretty much spot-in in terms of height above centreline, and a decent best fit above the flats. One side is a bit off, but the other is parallel, so the casing must be a bit lop sided. The flaw in the valve port machined out too. They might need some minor work with a file:
                  Next job tomorrow will be the feet recesses and the exhaust port facing. I might also drill the port mounting holes and drill the central hole to the valve face slot. I checked the depth of the exhaust hole from the valve face and that also seems spot-on to the centre pop I made (based on measuring the cast pad), so that’s given some more confidence the offsets are correct.
                  #558241
                  Dr_GMJN
                    @dr_gmjn
                    Always wanted to try using Rizla paper to find the surface of something, 0.0005” according to the verniers, so there we go…
                    Then machined the feet using the valve face as a reference:
                    Set up at 90 degrees to the valve face using a 1-2-3 block
                    Then faced the exhaust pad with a 12mm end mill. It only just cleaned up at the specified offset from the axis
                    Then puzzled over whether to centre using the valve pad as the reference, or the cylinder ends. There was a very slight difference. Same with the offset from the valve face. Only a matter of 0.004” or so in both cases, but in the end I used the valve pad and the exhaust pad as references:
                    Double-check with the port seemed to confirm it was about right:
                    And since I’m using the DROs, I ignored the instructions to mark from the port block, and drilled and tapped the securing holes:
                    The exhaust hole broke through right where it should:
                    Now to do it all over again with the other cylinder.
                    #560420
                    Dr_GMJN
                      @dr_gmjn
                      Struggling with motivation do to anything at the moment – maybe I’ve got too many projects on, or maybe it’s delayed lockdown blues. Anyway, got the other cylinder exhaust port and feet done:
                      They both seem to be ok in terms of heights and lengths etc., and the thickened Milliput flange isn’t really noticeable either. So the next thing I want to get done are the angled drillings for the drain cocks. I think I’ll drill and tap the feet for the cocks (or unions), then angle the cylinders in the vice and use the long series centre drill to start a hole, then drill and hope it breaks into the drain cock hole…
                      Then it’ll be on to drilling the cylinder cover holes and figuring out some revised hole positions for the valve chests:
                      That will be interesting seeing as they are a bit small, and the corner holes seem to have wafer thin edges.
                      #560433
                        I've never found the need to do the separate CSK screws to hold the chest in place, I always just use the studs that run right through and retain the cover. Easy enough to slip a couple of larger nuts over two studs to act as spacers so the chest can be held in place when the eccentric rod length is being set then no need to be able to hold the chest without cover after that.
                        If you still want to go with them then I don't see the need for them being 4BA, get some M2.5 or even M3 CSK socket screws and use those.
                        #560440
                        Dr_GMJN
                          @dr_gmjn
                          Posted by JasonB on 30/08/2021 20:04:25:
                          Yes it did seem a bit odd putting an extra four holes there, but I guess I'll do it anyway since it's per the instructions. I'll see what I've got in smaller sizes and use those like you suggest.
                          As for drilling the holes themselves, intention is to get the centreline of the casting from the mandrel, and use that as a left/right offset. Front/back will be from the exhaust port hole (which I've previously determined is in the centre of the face, and it matches exactly with the cast-in ports). I'll then drill that same offset pattern in the housing, using the rod holes as a centreline datum.
                          Also, I think the actual valve face is too small (according to the drawings), yet the un-machined valve chest casting seems to correspond very nicely to it. I guess all the holes therefore need offsetting slightly towards the middle?
                          Thanks.
                          #560475
                            Mine ended up being 1.348" wide rather than 1 3/8" so I just reduced the hole positions by the same amount to maintain the same edge distance, all set out from ctr lines.
                            #560485
                            Dr_GMJN
                              @dr_gmjn
                              Posted by JasonB on 31/08/2021 08:17:01:
                              So the boss for the packing is oval, and the sides of the chest need to be equi-distant from the central hole in the oval. I'm thinking get the centre of the oval, centre drill it, then somehow clean up the long sides on the mill, equi-distant from the centre hole, then do the offsets for the square faces, then set in the 4-jaw to finally drill the valve rod holes and clean up the end dome? Question is what order to do this in and how to get the equi-distant faces. I don't have a vernier height gauge. I'm wary of setting up non-machined faces in the 4-jaw, since I suppose I could get a skewed hole?
                              #560542
                                I think I just worked out which was going to be the narrowest of the three parts and reworked the hole positions to suit that. Set them up in the vice and located ctr of each and used the DRO to layout the holes then screwed them together and milled the sides so all were flush.
                                You then have straight sides if you need to tidy up the dome. Looks like I did the gland and rod hole sin the mill, screwed on the gland and then filed the boss and gland to a similar profile. The glands were missing from the engine I got so knocked up a couple on the CNC and also cleaned up the pipe flanges in the same way.
                                #560576
                                Dr_GMJN
                                  @dr_gmjn
                                  How did you mill all the sides flush? One has the dome in the way, one has the oval in the way and the other has the exhaust port on the cylinder in the way. Do you mean the cover to chest, or chest to cylinder or all three together?
                                  #560577
                                    Sides were done with a 50mm insert cutter, one side simple the other just taken as close as possible to the exhaust boss then finished with a file to blend boss into milled surface.
                                    You can see from the above that the chest was the shortest so not really anything to come off it's ends. With assembly in the vice cover facing upwards I milled the ends of the cover until they just came flush with the chest and noted the DRO positions. Then removed chest & cover so that the port face could be milled to those dimensions, probably used a 10mm cutter for that, Filed the last bits of the port face ends where they are below the flats on the top of the cylinders.
                                    #560615
                                    Dr_GMJN
                                      @dr_gmjn
                                      Thanks Jason. My intention – at present – is to paint the sides of the valve chest, and the sides of the cylinder valve face, but leave the edges and top periphery of the cover plate bright (recessed centre painted too). I think it might look ok like that, especially with the gasket line demarcations and the bright inlet block on the side as a contrast.
                                      So I think I’ll first fully machine the chest faces to depth, minimally machine the sides to clean up (there’s the inlet port on one side so it needs doing flat), minimally machine up the dome end in the 4-jaw, and file and flat the packing gland end by hand. If it then turns out short to fit to the cylinder valve face, Ill file the ends of the face to match.
                                      #561039
                                      Dr_GMJN
                                        @dr_gmjn
                                        I did some minor tidying up around the feet, and drilled and tapped the cylinder drain cock holes as per the instructions:
                                        The instructions call for an angled hole to be drilled from about 2mm from the end of the cylinder bore, to meet with the upper part of the drilled and tapped hole. It seems quite a shallow angle to drill (about 12 degrees to the bore by my calculation), so I'd have to start the hole in the bore probably using my long series centre drill.
                                        Question is, I think it would be much easier to just drill in from the end of the cylinder flange into the top of the drain cock hole, then drill down from the cylinder (obvioulsy at a very slight angle) to meet it:
                                        The hole in the flange would be sealed by the cylinder end cover and gasket.
                                        Is there any disadvantage to this method, or is there an easier way of drilling the single, slanted hole and ensuring it ends up breaking through towards the top of the drain cock hole? Obviously if it ends up lower, it could be blocked by the drain cock thread. Cheers.
                                        #561051
                                          It's not critical that the holes go right to the very end of the cylinder, any condensate will tend to be blown out between the gap around the piston either side of the rings/packing.
                                          Simple way to do it is to drill in from the tapped hole either straight or at whatever angle you can get, even starting where bottom meets side of hole will work and help the drill start.
                                          If you really want to get it right upto the spigots on the covers than rather than try and drill an angled hole like you show just use a 1.5mm milling cutter to make a small "D" shaped notch say 2.5mm deep so it extends beyond the cover's spigot
                                          A ctr drill will only be slightly more useful than a standard drill at starting on an angle, less so the steeper the angle or longer the ctr drill. Better to gently plunge with a flat or ball nosed milling cutter to give the drill somewhere to start
                                          #561065
                                          Dr_GMJN
                                            @dr_gmjn
                                            Thanks Jason. I'll go with the 1.5mm end mill method (similar to the 10V geometry IIRC). I've just got that sized milling cutter for the car differential output spigot job.
                                            Let's hope it survives…
                                            #561190
                                            Dr_GMJN
                                              @dr_gmjn
                                              Milled and drilled the 1.5 mm cylinder condensate drain holes as per above this morning:
                                              The drillings more or less line up with the tops of the drain cock holes, so all good:
                                              #561201
                                              Dr_GMJN
                                                @dr_gmjn
                                                I’ve got this profiled brass/gunmetal for the packing glands and the exhaust ports. They all need drilling centrally, and then two holes for studs each side:
                                                First question is how do you set the bar up to drill right in the centre, and get it square in order to offset the two securing stud holes, making sure they’re dead central to the section? For example on the valve boxes, I want to machine each side offset from the central hole to get the whole thing centred above the cylinder axis. So I need to drill that valve rod hole centre first as a datum for marking out, and for setting up in the 4 jaw chuck.
                                                Also, I’d like the gland/flange profiles to match their cast iron counterparts. As you can see they are all different. Is it a case of temporarily bolting them together, then filing one part and/or the other until the profiles match?
                                                Thanks.
                                                #561206
                                                  You can set the extrusion up in the 4 jaw checking opposite sides are central and then face and turn the raised central boss. Once turned blue the end with a sharpie and use your new height gauge set to lathe ctr height to scribe a couple of lines either side of the boss when the extrusion looks horizontal in the chuck, Square against a chuck jaw can help. Then increase height gauge setting to include half the stud hole spacing, rotate chuck 90deg and scribe one line, rotate 180deg and do the other. part off and repeat for the others. Carefully punch and then drill the stud holes.
                                                  Valve chest. File off the casting sprue, blue and mark out position of hole again height gauge make sit easy to do the offset height then measure overall width, half that and set gauge to that so you can mark it's position width wise and punch where the lines meet. Set up in 4-jaw so the punch mark runs true, face, drill, ream, countebore and drill the far end then mark out as for the glands or back into mill vice, locate ctr of hole and just use DRO to get the position of the two stud holes.
                                                  Yes screw them on and file to suit
                                                  Back to the Cylinders, have you gone deep enough with those notches? they need to be deeper than the 1/16" spigots on the cylinder covers unless you are going to machine clearance on the spigots.
                                                  #561226
                                                  Dr_GMJN
                                                    @dr_gmjn
                                                    Thanks Jason, so the extrusion in the 4- jaw is just aligned in the jaws by eye?
                                                    The drain slot extends 2mm into the cylinder, and the spigot is 1.6mm deep minus the gasket, so that should give about a 0.5mm gap. Is that enough? Could pocket the caps a bit, but since I doubt it will ever run in steam it might not matter.
                                                    #561232
                                                      As you are going to end up filing most of the extrusion's edges to match the CI bosses lining up with the jaws by eye should be fine unless you don't have a good eye for that sort of thing.
                                                      the problem is that they used to supply castings rather than the extrusion and they were more like the shape of the iron bosses which are really 3 circles and 4 tangental edges. If you get your rotary table then that type of shape is quite easy to mill so you could bolt on the flanges and locate the two parts under the mill spindle and machine to a nice shape.
                                                      This is what I machined the flanges too and the iron bosses only needed a very small amount of file work to match
