I'm renovating a Startrite Mercury MkI – 5 speed (age before 1965), it came without the on/off switch on left side and a different external switch/fuse arrangement. I may put an on/off switch there or a blanking plate. There were no screws in the nutsets, but the serial number plate screws fit, so I measured it up:
Outside thread: 3.47mm, 40 TPI (counted over 1/4''
This rules out M3.5 since the thread count do not fit either normal (pitch 0.6) or fine (pitch 0.35) and the diameter do not fit the wiki BSW or BSF tables.
I could be UNF #6, but I have another screw that measure 3.50mm, 40 TPI, but that do not fit. The screw that fit is not tight, so I guess it is not the 0.03mm difference but thread geometry?
If anyone know the what the thread is it would be appreciated.
