Brian, why not make your own as and when you need them, just use a piece of silver steel the size of the drilled hole then make a 4 flute cutter to lock onto it with a grub screw. Made lots of these inthe past, you can also make countersinks and reverse spotface cutters, cutters can be sharp cornered or as is usual in the aircraft industry with a corner radius.
Doesn't have to be SS for the pilot you an use BMS or whatever, we used SS as a convenience.
Regards John
