Serious Sun-Glass
Serious Sun-Glass
Home Forums The Tea Room Serious Sun-Glass
  • This topic has 47 replies, 17 voices, and was last updated 15 May 2025 at 20:45 by Michael Gilligan.
Viewing 23 posts - 26 through 48 (of 48 total)
  • #797568
    Robert Atkinson 2
      @robertatkinson2
      Bernard has mentioned something I was about to warn about.
      Don’t use polarised glasses when driving a modern car. The LCD displays rely on polarised light to operate. Depending on how thai aligins with your glasses ti cn prvent you seeing the display / dashboard. Also affects some phone / computer / TV screens. Thia has led to a reduction in popularity of polarised lenses.
      Dave,
      I’ve seen that done, both mechanically and electronically (liquid crystal) on aircraft cabin windows but never on a pilots visor. Do you know what aircraft this was on? I assume it was sometime ago as on modern aircraft there are issues with LCD displays and possibly Head Up displays (HUD).
      Michael,
      Very glad you are going to take professional advice.
      Robert.
      bernard towers
        @bernardtowers37738
        Strange thing is my prescription sunglasses are not polarised!!!
        #797620
        duncan webster 1
          @duncanwebster1
          The Dambusters used blue filters on the cockpit windows and amber googles for the flight crew so that they could see the instruments but even in daylight the outside looked dark. I’m not sure what the police would make of that if Michael trued ig on his car.
          #797631
            It’s mentioned in one of my schoolboy books on the wonders of aviation circa 1960.  No details or a picture, but I guess more likely to have been googles than a wrap-around type.
            Not sure about the advice to avoid polarising glasses whilst driving. Car instruments aren’t safety critical, but driving along a wet road into the rising or setting sun is!  That’s when I wear them.
            I wonder if ordinary glasses are frequency sensitive, and might block LED light disprortionally. Cheap glasses tha block visible light but not UV are famously bad for the eyes.  Fooled into thinking it’s dim the iris opens and lets UV into the retina at full blast.
            I’ve read that sunglasses are rarely necessary in the UK (normal eyesight adapts) and they cause accidents.  The auto-darkening type take so long to clear that drivers go blind for minutes at a time.  I’ve even seen drivers wearing them at night.  Poseurs…
              For what it’s worth … I asked Google about the original ‘privacy glass’ in my Vitara:
              IMG_0777
              The reason for so-doing was to get some sort of baseline for my discussion with the  Optician.
              I have noticed that my rear-view via the mirror and the privacy glass is [when also using the sun-glasses] reasonably comfortable.
              Pretty meaningless without a spectrometer and a photometer to hand, but it might give us some hints.
              P.S. __ for completeness
              I found the tag from the Foster Grants
              IMG_0779
              #797663
                Here’s a useful reference document that might be of general interest:
                https://www.abdo.org.uk/wp-content/uploads/2012/04/Eye-protection_safety-and-protective-eyewear.pdf
                duncan webster 1
                  @duncanwebster1
                  I made the mistake of getting reactolite lenses many years ago. Up a mountain in winter, thick mist, freezing cold. Reactolites pitch black. Fortunately i can see well enough to mznagd without, especiallg as i cojldnt see mord thfn 50 meyres eigh ghf mist anyway. According to the optician, sensitivity goes up as temperature goes down, and whatever wavelength triggers the darkening goes straight through mist. Scrapped the lenses.
                  #797767
                  Robert Atkinson 2
                    @robertatkinson2
                    Dave,
                    A lot of materials can have unexpected optical transmissin characteristics. Some that look clear e.g. normal glass block a lot of UV and some IR while some that are opaque to visible light and look black pass UV (woods glass) or IR (“black” acrylic). Polycarbonate and acrylic block most UV but some common resins used for spectacle lenses e.g. CR-39 don’t. So clear safety spectacles block UV but sunglasses may not.
                    I know one manufactuer, Ray-Ban IIRC, had a specific “tint” for drivers that had a “hole” in the red portion of the absorption spectrum so brake lights and red traffic lights stood out.
                    I once had troule getting a machine with an internal 254nm UV light and a lightly tinted acrylic full width “door” past a UL (USA insurance recognised safety standard) approval inspection. The inspector would not accept that the plastic blocked UV dispite being shown data from the manufacturer. He was worried about exposure to users. I had to go and buy a UV photometer to prove there was no detectable UV. I even had a couple of plastic samples. One thinned to 10% another with a several 1mm holes drilled in it. Neithe passed any measurable UV. After the inspector signed off the machine I pointed out the OSHA (US health and safety) has no exposure limit for UV radiation to workers or public…
                    Only a transmission spectrophotometer will tel lthe whole story.
                    #797778
                      I am hoping for an interesting and productive visit to my Opticians tomorrow, and will of course report back.
                      My current working hypothesis is that the problem relates to Violet rather than either of the UV bands.
                      For a glimpse of  my logic, see the Foster Grants tag and also my earlier note to Kiwi https://www.model-engineer.co.uk/forums/topic/serious-sun-glass/#post-797264
                      … I’m guessing I might end-up with Amber [i.e, Violet-blocking] filters.
                      Edit: __ modern dichroic filters are astonishing !
                      https://www.edmundoptics.co.uk/document/download/396611
                      https://www.edmundoptics.co.uk/f/additive-and-subtractive-dichroic-color-filters/11985/
                      #797796
                      Robert Atkinson 2
                        @robertatkinson2
                        Those are pretty basic filters. The high perfomance ones have passbands of a few nm. The price is mugh higer though. I have quite a selection of them that were used in various fluorescent imaging and measurement instruments. This is a basic one https://patents.google.com/patent/US6878949B2/en
                        I’m back in aerospace now so little use for the filters. I did try a green one on a replacement lamp for my H&W autocollimator but a highe powe LED was much better.
                        Robert.
                        #797798
                        Kiwi Bloke
                          @kiwibloke62605
                          Michael, you’ve probably got there already, but there is quite a bit of info. on the ‘net about the transmission characteristics of the human eye’s lens (and other components of the eye), and age effects. Here’s just one: https://iovs.arvojournals.org/article.aspx?articleid=2129060
                          It seems that the transmission characteristics of replacement lenses varies with type. You should be able to discover the characteristics of that with which you have been fitted. Perhaps that would allow a better tailored filter for your ‘shades’.
                          Regarding the warning about polaroid and driving… In bright sun, I find the reflected image of the top of the scuttle interferes unacceptably with my view through the windscreen in some vehicles, one of the worst being our Jazz. Polaroid sunglasses therefore become a necessity! Since mine do not have ‘progressive’ lenses, they produce two mechanisms making the reading of the speedo., etc. a bit of a problem. I think being able to see forwards is a bit more important…
                          #797800
                          V8Eng
                            @v8eng
                            I shall be very interested in the outcome of your visit to the optician.
                            My wife and I had cataracts done in both eyes about 4 years ago.
                            We used the same consultant and hospital but my wife has become hyper sensitive to bright light and needs to wear sunglasses very frequently but I do not have issues with bright light.
                            The consultant appeared rather puzzled by my wife’s problem whereas the optician thinks that the issue is partly caused by weakening of the muscles controlling her iris and is somewhat age related.
                            As an aside my new lenses claim to restrict both uv and blue light.
                            Unfortunately my wife cannot currently locate the card for her lenses but I am quite convinced from memory that they are of the same make and type as my own.
                            #797931
                              [ <b>A VERY HAPPY ENDING</b> ]
                              After a long, and very thorough eye examination at Morans Opticians we discussed the glare/flare issue and, to cut a long story short, I ended-up purchasing [off-the-shelf]
                              454 Wailua, by Maui Jim
                              [ no, I had never previously heard of Maui Jim ]
                              https://en.wikipedia.org/wiki/Maui_Jim
                              I tried several alternatives, but these worked beautifully FOR ME
                              Please note; I am NOT suggesting that they’e a universal panacea.
                              The drive home was the most comfortable “bright light” journey that I’ve had in a long time.
                              Now, to be just a little smug … here are photos showing [very approximately] the reflected and transmitted colours of the lenses, for comparison with my ‘working hypothesis’
                              .IMG_0780
                              IMG_0781
                              Grizzly bear
                                @grizzlybear
                                Michael,
                                Well done.
                                Glad you got it sorted.
                                #797952
                                V8Eng
                                  @v8eng
                                  Michael.
                                  very pleased you got it sorted out.
                                  Certainly something to possibly investigate further in the wife’s case.
                                  I can’t see your photos on my iPad though, just rectangles containing squares with ? marks.
                                  #797955
                                    Photographs re-loaded after processing through CropSize App
                                    IMG_0780
                                    IMG_0781
                                    Hopefully this will override the foibles of this forum … Grrr !!
                                      Thanks, Grizzly and V8
                                      Just a couple more notes whilst I remember
                                      • In reality [whatever that may be], the reflected colour is bluer and much shinier than it appears in my image
                                      • The transmitted colour is certainly noticeable, but is not intrusive
                                      • They appear to be polarised, but in a very subtle way [this warrants further investigation]
                                      As our American friends might put it “Your Mileage May Vary” … but for  V8’s wife and anyone else suffering similar problems, I would highly recommend trying them.
                                      I’m happy to either stop the discussion now, or let the topic drift on
                                      … I find it interesting for its own sake, but others may not.
                                      Thanks to everyone who contributed.
                                        For the record …
                                        Mine were done in 2017
                                        It is most unlikely that the UV light is causing my over-load problems … but rather that the Violet/Blue is getting scattered by irregularities on the cornea.
                                        [ just think of it like a scruffy old camera lens ]
                                          Last one for this morning:
                                          The image on this page can be ‘wiped’ using the little triangles, and provides a good indication of my experience … except that my ‘without’ is orders-of-magnitude worse than they illustrate:
                                          https://www.mauijim.com/GB/en_GB/lenspage
                                          Edit: __ to a rough approximation … my ‘without’ would probably look more like this:
                                          .Posture
                                          #797971
                                          Robert Atkinson 2
                                            @robertatkinson2
                                            Glad you got sorted.
                                            The transmitted picture still does not show for me. What colour (perceived) is the transmitte light?
                                            As well as scattering blue light can also cause fluorescence in parts of the eye. This is why it’s hard to focus on bright blue lights, think LED decorative lights. Maybe the operation has changed this response in your eyes.
                                            Robert.
                                            #797976
                                              The transmitted picture still does not show for me. […]
                                              Apologies … This forum is getting beyond a joke
                                              I will post a numerical description instead
                                              This is my best effort for now …
                                              RGB 101 56 0 144
                                              #797983
                                                Posture
                                                #798134
                                                  [ NOT FOR THE SQUEAMISH ]
                                                  Effectively my corneas are degraded, on both their inner and outer surfaces
