recent power outage in Medway
Home Forums General Questions recent power outage in Medway
Viewing 20 posts - 26 through 45 (of 45 total)
  • #586645
    Ex contributor
      @mgnbuk
      this afternoon our central heating stopped working, we still have hot water but the heating circuit will not function
      Do you have a combi or a system boiler Dave ?
      If yours is a system boiler, check the 3 port valve. Failure of the valve syncronous motor doesn't switch over from hot water to heating. But the valves have a manual override lever – if you actuate this (they are stiff to operate against a strong spring & reduction gearbox) & the heating then works, it is probably the valve motor that has failed. Manually toggling the valve on can keep you warm until the proper fix arrives (there is a "park position" notch in the housing to hold it in position). My 3 port valve motor has failed twice in the 28 years I have been in this house – a relatively cheap & easy fix, though, at (currently) just over £15 from Toolstation.
      If yours is a combi boiler, I can't offer any possible solutions as I have no first hand experience of the unreliable things.
      Nigel B.
      Edited By mgnbuk on 21/02/2022 19:15:50
      Samsaranda
        @samsaranda
        Nigel, it is a combi boiler and I have checked that there are no error codes being displayed on the boiler so it looks like the room thermostat is not working, it is a wireless unit and has been in place for ten years with no problems, and no alterations in the house to cause it any problems. Have changed the batteries and retuned the sender unit to the receiver, no joy the boiler tries to initiate but just shows that the fan is purging as if the attempt to fire up has been aborted. We still have hot water from the boiler so nothing drastically wrong with it. The system is covered by a full maintenance contract and the engineer is scheduled to visit tomorrow, hopefully full heat will be restored, until then the centre of operations is the lounge where we have an inset woodburner which can give up to 7 kw of heat. Many thanks for your help, Dave W
        #586705
        Joe McKean
          @joemckean81940
          Whatever happened to just the plain old good power CUT
          #586708
          Andrew Tinsley
            @andrewtinsley63637
            Plus one for the above. I sometimes think that I live in the USA and not the UK. Plus "cut" is shorter than "outage" so keep it simple.
            Andrew.
            #586742
            Swarf, Mostly!
              @swarfmostly
              Several months ago, it became obvious that our central heating system had stopped working. It was freezing weather and my first thought was that an excess of ice had built up in the condensate drain. We are Housing Association tenants so I phoned and reported a fault. It was 'after hours'.
              The duty repair guy called us back and asked what error codes the boiler was displaying. He then suggested that I wind the wireless thermostat control knob up and down vigorously several times and he would call again later to learn whether this had been successful. I was able to report that this had fixed the problem.
              He and I diagnosed that I had had occasion to switch off the mains electrical supply earlier that afternoon – this had caused the wireless thermostat on the hall wall to 'forget' its link to the receiver unit in the airing cupboard.
              I was inpressed with this remote problem solving that avoided his coming out so he was meanwhile able to respond to calls from other tenants.
              Best regards,
              Swarf, Mostly!
              #586781
                Posted by Joe McKean on 22/02/2022 10:16:30:
                Pedant alert!
                Criticising English is terrible hazardous! There's an order rule: 'opinion, size, age, shape, colour, origin, material, purpose'. Joe should have said 'Whatever happened to just the good old plain power CUT'. For the same reason we have to refer to the Big Bad Bear, not the Bad Big Bear.
                Alert over.
                I'm OK with outage, a word I heard at work 50 years ago. True it's an Americanism like 'shortage', but both words are useful. I suppose the Americans coined them from British English stock-control words like baggage, dosage, breakage, coverage, storage, tonnage, luggage, usage, spillage, vintage, spoilage, salvage, shrinkage and wastage etc. Nothing unpatriotic about them.
                HOWARDT
                  @howardt
                  While catalytic has heaters don’t need a flue they do need a suitable air vent for input air. Also you have to be aware of the room volume minimum requirement. We have a fixed catalytic gas fire in our lounge, highly recommended very efficient.
                  #586841
                  Joe McKean
                    @joemckean81940
                    Point taken SOD, I wasn't in any way criticising the grammar it was just the use of the word outage.
                    Got to go now and get those diapers that I left in the truck of my station wagon ( it's all just humour )
                    Joe
                    #586843
                    Clive Hartland
                      @clivehartland94829
                      I would think a power cut is where it would affect just an item or say a house, an outage is where a whole area is without power as in my case in Medway, where over 300 houses were affected.
                      The after effects to me being chilled were like having the Flu, muscle and joint pains etc. it has taken a few days to wear off physically so I feel I may have been on the way to being frozen.
                      It was several hours before the thermostat was up to heat.
                      #586846
                      not done it yet
                        @notdoneityet
                        Posted by Clive Hartland on 23/02/2022 07:44:33:
                        Nowhere near frozen, but body core temperature only needs to drop a couple of degrees Celsius before things become very serious. Extremities are starved of blood circulation to preserve core temperature, long before that, so fingers and toes start to lose sensation (beyond feeling cold). If one’s body thermostat is not working too effectively, it can take some time to get things back on an even keel.
                        #586858
                        Nigel McBurney 1
                          @nigelmcburney1
                          My 35 year old 1900 watt (max) honda generator has just run for 45 hours from fri to monday, it will power the oil heating boiler and some lights,plus freezers and fridge selectively,and I have changeover switch and run the honda in the garage which is detached from the dwelling, plus we a have a log burner stove in the lounge,so we have one source of heat which requires no power.but due to the risk of fire and the small fuel tank i could not use the honda to run the central heating overnigh problems with this set up, 1900 max 1700 continuous , watts will not power the micro wave , the electric garage doors a recent installation are supposed to have an emergency release ,in practice for an 80 year old was difficult ,so I went in through the side door fire up the honda and it did struggle to opearate to raise the door, i did not use the micro wave as its a bit too close to the generator limit,so we did not have an oven, only a 2 ring camping gaz burner, so ready meals are out. I would not risk using bt router and computer in case this old generator blew it all up though I did risk using the TV, so cooking and communication was not easy, Mobile phone signal is weak, Now speaking to a open reach engineer ,BT is changing all uk land line phones to digital by 2024 so in future when the power is down and old style phones which need no power will not work,so it will be a case of using an emergency battery pack ,or inverter type generator with regulator control to power modern electronics, the honda equvalent to my existing generator is around £1300 though there other makes cheaper oriental makers which raise the question of long term reliabilty.My location is rural and isolated and power cuts are common . current thoughts to improve the situation are buy a 3000w generator with fuel tank capacity to run all night and regulated current that will safely drive electronic devices and telephone. or get a 2000w inverter generator to run the house and get the lowest power microwave and use the existing generator to run it. Another problem did occurr ,the old Honda has been an execellent starter provided there is fresh petrol in the tank, use this modern e10 petrol and leave just a drop in the carburretor and it gums up into a green sludge and blocks the main jet. The mains came on yesterday in the afternoon ,so I put all gear back into store then at 6 pm it went off luckily I found out that it was only for 2 hrs for a reconnection a mile down the lane.
                          #586873
                          Andrew Tinsley
                            @andrewtinsley63637
                            Re the motor failure on 3 port zone valves. I have never had a failure of a motor in nigh on 50 years. BUT I have had frequent failure of the microswitch limit switches. So if you have a dud 3 port valve and the motor still works, then check the microswitches!
                            I have two motor heads in stock with new microswitches fitted so that I am ready to change the motor head when the next microswitch fails.
                            Andrew.
                            #586904
                            duncan webster 1
                              @duncanwebster1
                              If you had an electric car and a suitable inverter you could run the house off the car battery for quite a long time.
                              #586905
                              Ex contributor
                                @mgnbuk
                                Some recent electric cars have a "power out" function rated at a couple of kilowatts – the Hyundai advert used to "sponsor" Film 4 ad breaks shows a projector being plugged in to the car's 13A 240v outlet.
                                Nigel B.
                                #586922
                                larry phelan 1
                                  @larryphelan1
                                  Clive, my Mother, and many more like her, lived to be 95 and never knew anything other than an open fire.
                                  She would not have an electric blanket and regarded radiators as little more than tin boxes on the wall.
                                  I am 83 and still do not make much use of my oil heating, one tank full, 1000 lters lasts me for 18 months, mostly used to heat water for showers and sink use..
                                  Get yourself a dog, walk a lot, keep warm, save the Planet !cheeky
                                  #586934
                                  colin hawes
                                    @colinhawes85982
                                    Regarding power disruption I was taught that "outage" is an accidental power failure whereas "cut" is a deliberate disconnection . Colin
                                    #586951
                                    ChrisH
                                      @chrish
                                      We also had a power cut last Friday here in the South-West, but only for about six and a half hours. We managed as we have a gas fire in the lounge and a single ring camping gas stove for heating food/water for tea, plus the electric Aga takes ages to cool down so we made use of the oven in that whilst it was still warm.
                                      However, two doors up there was a young family (two young children) whose power cable had come down on the Friday. The cable was made safe on the day but wasn't renewed until the following Monday evening, after which one of the engineers called at our house to see if we were ok as he could see no lights in our house from the road. Interesting talking to him, they had already put over 580,000 properties back online with more to do, their repair team hadn't been home since Friday, they were just working all hours then sleeping in their vans, they had taken on over 1000 temporary staff to help cope – and, incredibly to my mind, had received no end of abuse. Why for goodness sake, they are trying to fix it, they didn't cause it. There are some mindless morons out there.
                                      What we couldn't do with the power down was make a phone call – our landline phones are modern digital pick up and walk around the house jobs and the mobiles lost all signal. It was suggested we get an old analogue phone, which we now have, which will work in a power cut they tell me. Now I read BT in their infinite wisdom will make that useless in a couple of years by turning all landlines into digital; progress isn't always a good thing. That is really encouraging for the elderly vulnerable living in the sticks. Does nobody ever think these things all the way through?
                                      One the subject of boiler heating hot water but not the heating circuit, we have twice in the past few months have our combi boiler lock out due to the overtemp cut-out within the boiler case actuating. It is situated right over the silly three port valve which had stuck in teh hot water position. I think what must have happened is that the heating system repeatedly called for heat, the boiler tried to respond but being stuck in HW mode just ended up overheating itself. Both times it cleared by me manually operating the valve as described above by Nigel B and away it went again, though I admit that the last time I did spray electrical contact cleaner around in a hope that if it was just a manual sticking of the vavle. Note to self, must get a replacement motor unit – only £15 in Toolstation it is claimed!!
                                      Chris.
                                      #586956
                                      Clive Hartland
                                        @clivehartland94829
                                        I have decide to have a standard gas fire re-fitted. Had to remove the old one as it was leaking.
                                        Now to start looking for someone to do it to gas standards.
                                        #586962
                                        Martin Kyte
                                          @martinkyte99762
                                          Well done. There comes a point when you have to start spending the money you saved up for a rainy day.
                                          Keep cosy.
                                          regards Martin
                                          Edited By Martin Kyte on 23/02/2022 19:46:09
                                          #586967
                                          pgk pgk
                                            @pgkpgk17461
                                            We own an analogue phone for the reasons Chris mentions but it'll only work plugged into the incoming 'master' socket which for reasons unknown is halfway up the stairs.
                                            I’d guess the intention to go digital on the incoming phone lines is to avoid needing both fibre and copper? And the assumption that everyone has a mobile signal in their area – I wish.
                                            Perhaps a small UPS to power up routers and digital phone systems for folk that don't.or can't run a generator?
                                            pgk
