Does anyone have any experience with polymer bearings such as DU or DX from GGB (Glacier) or the more modern composites from Igus?
Yes Jonathan, I've had 12mm Glacier DU bearings in the axleboxes of a 5" gauge 0-6-0 diesel outline loco for, I think, 4 years now, and have in the last few months had to take a wheel off an axle, so I had the opportunity to inspect two of the bearings.
Perfect condition, no detectable wear on the axles, other than the chemically blackened finish of the axle being worn off in the bearing area. The DU was nicely run in, exactly as expected from the DU literature.
The other two axles were removed, but not dismantled. The axleboxes felt in good condition.
All axleboxes and DU bearings were re-installed to the loco, so we'll see how they go from now on!
Also some experience of the Igus bearings, in one of Dave Noble's wagon kits, carrying a load of 28kg. Been running for one season now, and again recently inspected. They look good so far!
Oh, and I know of a chap who fitted very small DUs in the Walscheart valve gear of a 5" gauge Black 5, which has been running for some years. Not seen him for quite a while though, so I can't say how well they've performed since the last time we met up.
