What Jason is saying is that if the saddle can lift. It can ride up and down the Vee of the Prismatic bed, and be able to move to and fro across the bed.
If the lift is minimised by adjusting the bolts and gib screws, the saddle cannot lift, so it cannot move to and fro across the bed.
So tighten the bolts, and then adjust the gib screws to minimise lift, and the movement should then be reduced to an acceptable level.
Just as the LMS video shows.
