Martin, here is a link to the gearbox manual
Forgot to say how old is your machine ? you can check the age with the serial number on the Myford site, earlier machines may well have a different gearbox and the installation is different
Broadly for what you need to do there are two type of lead screw, the later one passes through the gearbox to the gear train, the earlier one is connected to the gearbox with a sleeve on the RHS of the box. There may well be variations to this as well. My S7 is c1977 with power cross feed and I did have occasion to remove the apron, from memory – first remove the gears on the LHS inside the change wheel cover then the dowels and screws on the RH end of the machine to release the lead screw support bracket, make sure the half nuts are open then withdraw the L/screw.
Edited By JohnF on 10/12/2019 18:54:00
Edited By JohnF on 10/12/2019 19:02:30
